Home > In Car Electronics > Bolt on Bits RDX flasher Relay does it work as claimed |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20546 |
It's a requirement if towing as far as I am aware.
23rd Apr 2014 6:41pm |
trouble is some new cars having bulb failure display on dash will give you a warning you have a trailer bulb out , so don't need a extra light on dash or buzzer , so the regulation of having a extra flashing light for trailer or buzzer is not needed.
23rd Apr 2014 7:04pm |
Crasher Member Since: 17 May 2014 Location: Douglas Posts: 6 |
Hi
I fitted the RDX indicators from Bolt on Bits to my 1997 110, changed the relay to the one supplied and when I turn left or right the hazard lights come on. Changed the hazard switch, still the same. Tried the relay in another defender with the same lights and works fine. Has anyone come across this before or got any suggestions on how to fix it? thanks |
17th May 2014 12:04pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
Have you got side indicators on the wings with incandescent bulbs if so check that the bulbs are OK. I had a similar problem with LED indicators (although mine were WIPAC) and discovered that one of the side repeater bulbs was corroded changed it for a new one and everything worked fine.
17th May 2014 12:12pm |
The passenger side doesn't work, changed the bulb but still doesn't work. Not sure how to get to it to see if the wiring is
damaged or connected properly, would I need to take the wing off? Please say no |
17th May 2014 12:17pm |
Take off the lights or add one at a time until you find the culprit, other than that it will be wiring investigation.
17th May 2014 12:38pm |
No it should flip out if you have the orange oblong one it just a is push fit into the wing with two plastic pins if you have the later small square one that also will just flip out. I am sure that the bulb will be your problem as I said I had similar issues and once I sorted out the bulb all was fine! |
17th May 2014 1:13pm |
To remove the side repeaters you should push forward and should come out the side nearest the back.
The TD5 & Puma ones are like this anyway |
17th May 2014 1:15pm |
Thanks for the replies.
It was the side indicators . A loose connection on the passenger side. All working fine. Again thanks for the help. |
17th May 2014 2:42pm |
17th May 2014 4:27pm |
No probs, thought it would be the side indicators. |
17th May 2014 4:35pm |
