Home > In Car Electronics > Bolt on Bits RDX flasher Relay does it work as claimed
gilarion
Bolt on Bits flasher Relay
Has anyone fitted the Bolt on Bits RDX LED flasher relay and if so does it do what it says on the tin.
I have fitted a Set of WIPAC Led indicators lights and I am pleased with their performance, I have also fitted the supplied WIPAC relay, but like others who have done so I have both the indicator and trailer warning light flashing at the same time, even though I have no trailer attached, I can I suppose live with this, but having read that the Bolt on Bits RDX relay stops the trailer warning light flashing when indicating without a trailer, this I would prefer. Trouble is at £29.99 I really need to know if indeed the RDX relay works as Bolt on Bits says
‘Well ours puts the trailer light when you are actually pulling a trailer. When you are driving without the trailer and you indicate the little trailer light will not flash’
Any help gladly received.
Post #325369 22nd Apr 2014 5:49pm
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
Yes it works as advertised DEFENDER XS UTILTY 110 AUTO
ONLY ACCURATE GUNS ARE INTERESTING
Post #325374 22nd Apr 2014 5:54pm
keith
Mobile centre on here will also do the plug in relay for led indicators .
Post #325379 22nd Apr 2014 6:01pm
munch90
it works as long as you don't have led lights on trailer
Post #325380 22nd Apr 2014 6:03pm
I'm confident enough to believe what I've heard.
I went for the RDX LED lights, and I am pleased with those too.
I have the indicators front and rear, just need the relay now too, but like you say at nearly £30 they aren't cheap. But you get what you pay for on the flip side.
Post #325382 22nd Apr 2014 6:04pm
Well it will still work but just with resistors on the trailer. Thumbs Up
If it's ordinary incandescent lights on the trailer then no problems at all. Mr. Green
Post #325383 22nd Apr 2014 6:06pm
gilarion
I have a Bateson Trailer and a Elddis Caravan both have ordinary incandescent bulbs fitted.
If the RDX flasher relay works then I will probably go for one, especially as I have heard that some LED relays can blow when a trailer is hooked up.
Post #325386 22nd Apr 2014 6:13pm
Green Machine
Mine definitely works with no trailer and it definitely works with a trailer with filament bulbs. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #325387 22nd Apr 2014 6:16pm
The RDX relay can take up to 120w.
Two trailer indicators that are incandescent will be about 42w the pair (21w each)
That doesn't include the LR's own indicators too of course but that isn't much wattage.
Post #325392 22nd Apr 2014 6:23pm
munch90
I brought a flasher unit years ago that can take all led or all normal bulbs or mixed , has max load of 160w ,it's three pin so won't work the trailer light on dash at all so I fitted a buzzer for indicators which I prefer to be honest
I brought a Rdx adjustable flasher unit , but having led lights on my trailers it wouldnt work the dash light , (yes you can fit resisters but I think that defeats the object of having led lights in the first place )
but I removed it before it left my workshop as I found the flash rate looked a bit slow ,it was still within mot regulation speed , but I thought the flash rate looked a bit old fashioned like the old bi-metal flasher units , but that's me being fussy
Post #325400 22nd Apr 2014 6:35pm
keith
When I fitted my led indicators I didn't know about the simple plug in relay , so wired and soldered resistors to each corner only to find that the lamps were still flashing fast and the only way to sort it out was to also re-wire back in the original bulbs and holders . Aarrrrgh Banging Head Now I have spaghetti wiring and a bulb rattling away inside each corner .
Only to be told after all that work " there's a relay to save you doing all that "
Post #325407 22nd Apr 2014 6:48pm
Just snip it off and put female Econoseal connectors on the LR side and male Econoseals on the lights side. Thumbs Up
Post #325433 22nd Apr 2014 7:25pm
munch90 wrote:
I brought a Rdx adjustable flasher unit , but having led lights on my trailers it wouldnt work the dash light , (yes you can fit resisters but I think that defeats the object of having led lights in the first place.)
True, but if like me I don't tow that often so it's worthwhile. I'm not a fan of resistors either but for that small compromise you retain full OE functionality for the LR.
That IMO is worth it, much better than having the trailer light on all the time.
Yes it flashes the once and off but IMO if an MOT spotted it for a start flashing constantly I think he'd think ah hah there seems something funny here..
After all it's self explanatory by being a trailer symbol and it's obvious that it shouldn't be on when not actually towing.
I doubt there is any issues ensued by that but it could well be viewed with suspicion.
Just a shame about the trailer functionality or it would be a near perfect device.
Post #325441 22nd Apr 2014 7:33pm
munch90
mines not on ever , not first flash or when trailer on , that's why I fitted a buzzer which I have had tell me the trailer indicator had gone out and to be honest I don't think I would have noticed the light on the dash not flashing when trailer light out on a busy junction when you shouldn't really be looking at your dash
Post #325444 22nd Apr 2014 7:39pm
SGH
Wipac on works fine on my 130
Post #325466 22nd Apr 2014 8:17pm
