Home > Maintenance & Modifications > CB installation in Cubby
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
I want to install my Cb radio inside the cubby along the sloping side.
Was thinking of putting this in so I could just slide the radio in (after getting a suitable din adapter for the radio
Anyone done this - any tips or hints
Also, any pics of cubby installs I could look at for ideas?
Thought about the MUd roof console but probably overkill ( and costly) as only use CB occasionally when laning in a group
Post #330350 11th May 2014 7:13pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I've done exactly this, only I used the bracket that came with the CB to fasten to the inside of the slopy bit. I have put a gas strut on the lid to keep it open when using the CB.
It's spot on.
Simon
Post #330355 11th May 2014 7:25pm
kmac
Thanks couplands
Any chance of a link to the gas strut?
Post #330357 11th May 2014 7:29pm
couplands
It was something like this, can't remember the exact rating I got, but it's not very strong.
http://www.ebay.co.uk/itm/Gas-Strut-Lid-St...3f2761a8f0
Simon
Post #330373 11th May 2014 8:04pm
kmac
Cool, thanks again
Post #330382 11th May 2014 8:15pm
couplands
Added some photos so you can see the installed CB. I did have it on the underside of the lid, but it was a bit hard to see the screen with my poor eyesight..Smile
Simon
Post #330541 12th May 2014 2:35pm
kmac
Post #330544 12th May 2014 2:53pm
kmac
Very nice Simon. I have ordered the gas strut - will look to do pretty much an identical install to yours.
Thanks for the help.
Where did you take you earth and power from? I am planning ti take power by tapping into the cigarette lighter fuse so its ignition switched power
Still deciding on where to take earth from
Post #330545 12th May 2014 2:56pm
couplands
I installed a fuse box (6 fuses) on the inside of the cubby and took +ve & -ve from the battery. It isn't switched, but I wanted to be able to use the CB and other accessories without the ignition on. I ran the cables though existing grommets in the battery box and under the cubby box, then drilled a hole in the cubby to bring the power to the fuse box.
On the dash board, I've tapped off the back of the cigarette lighter for anything I want switched.
Simon
Post #330547 12th May 2014 2:59pm
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
Couplands - on a slightly related point (apologies to OP for this thread hijack) what type of wire did you use to power you fuse box. What size were the +ve and -ve wires? 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #330602 12th May 2014 6:32pm
Another option Thumbs Up
Post #330611 12th May 2014 6:45pm
kmac
Nice ken, looks neat. I want mine hidden away though
Post #330614 12th May 2014 6:50pm
Mr. Green Thumbs Up
Post #330615 12th May 2014 6:53pm
couplands
I think I used 1mm or 1.5mm thin wall. It's rated at either 16.5 or 20 amp, which I thought was enough for the CB and a couple of charge points.
Hope that helps.
Simon
Post #330630 12th May 2014 7:10pm
