Home > Puma (Tdci) > MOT question
johnnyd
MOT question
Hi all, quick question, can i take a defender anywhere for an MOT or should it go to a Specific LR MOT place if such a thing exists ?
JD 2008 TDCi 2.4 XS CSW
Post #330274 11th May 2014 4:05pm
munch90
anywhere
unless you want to take it to somebody who knows land rover then a lr garage or indy
pass rate and test should be the same
Post #330275 11th May 2014 4:06pm
johnnyd
blimey that was quick Rolling Eyes
Many thanks
Post #330279 11th May 2014 4:12pm
I take mine to Ford, to my mind if you go to a specialist your more likely to failed as they'll know many specific points to look for issues.
Whether that's good or bad is something to consider though.
But that's what I do and had straight passes every time.
Priced at £40 too.
Post #330286 11th May 2014 4:18pm
munch90
just out of interest
there is a few changes being made , vosa are merging with someone else or just changing name to make dvsa
testers smart cards are going (the id card they use to log on to do your mot)
the vts system is going (the computer they use to put your details in)
they going over to normal online system (vts was still on dial up old style system , they said broadband was not secure enough before ! )
I think not sure you maybe able to book online as well soon
none of it makes the actual test different
Post #330290 11th May 2014 4:36pm
martinfiattech
Any testing station can do it, just remind them it`s permanent four wheel drive.
Transmission braked for brake test,
You may have to show the tester how to use the transfer box lever, remind them the hand brake with transmission brake only needs to hit 16 % to pass.
Locking up is not required.
If they go a bit errmmm they can do a tapley test on it by driving it down the road.
I use this test my self if there is any doubt in my mind to 4 wheel drive selection, a lot less trouble than a smashed gearbox, and vosa getting informed.
We are a green testing station and I for one want to keep it that way,
Already watched one defender come out of a set of brake rollers under test could have been nasty, luckily no one was hurt, and nothing damaged. Excuse the spelling I`am better with spanners and wires.
Post #330292 11th May 2014 4:45pm
johnnyd
hmmm so i rang my usual garage up and said do you do Defender MOT's they are a bit different, and he said as long as it will fit on his ramp he can do it, there is nothing different about defender (4x4) MOT's
Should that alarm me ?
Post #331333 16th May 2014 7:50am
SailingTom
Well he's right. I dont understand why you'd be alarmed?
Anywhere can do an MOT on one its no more specialist than any other vehicle on the road Very Happy Defender puma dormobile camper
Post #331335 16th May 2014 8:05am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
^^^apart from permanent 4 wheel drive and transmission brake as mentioned above.
If they think the car is the same as any other, that might be something to check.
I take mine to the local indie, but it's also the closest...Smile
Simon
Edit: sorry I might just have missed the irony in the previous post Shocked
Post #331336 16th May 2014 8:12am
johnnyd
YEY .....Passed MOT, he failed it initially as he said the ABS light wouldn't extinguish, but I then said to him I don't think it goes off until you drive off, which i proved to him, so he passed it then a bit reluctantly.......is it normal for it to not go off when stationary ?
Post #332319 20th May 2014 4:10pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Yes, Goes of after you've travelled 20 0r 30 feet, sorry 8-10 metres Thumbs Up
Steve
Post #332321 20th May 2014 4:23pm
K9F
K9F wrote:
ABS light does normally remain on until you reach 5-8mph then goes out. Thumbs Up
All you need to know about TC & ABS...... Thumbs Up
http://www.defender2.net/forum/topic22863.html?highlight=8mph If you go through life with your head in the sand....all people will see is an ar5e!!
Post #332323 20th May 2014 4:27pm
munch90
mot bay had a easy day today , highest mileage in today 543 , lowest 134miles
that's 534miles not k not thousand , just 543miles and 134miles total miles , not miles since last test
Post #332360 20th May 2014 5:58pm
martinfiattech
jonnnyd,
If the tester you used had any nouse he could have checked the abs sequence via the vts device or the mot method of inspection sheet. I think it`s the vt 40 ( do it every day should really make a note of the sheet reference numbers )
This is printed out by the vts computer
If that fails, all testing stations have warning light charts to check the vehicle by, I think its the law I know we have them he can always ring the vosa testing helpline.
There is always the vosa mantra if in doubt pass and advise. Excuse the spelling I`am better with spanners and wires.
Post #332424 20th May 2014 8:13pm
