Home > In Car Electronics > Replacing standard LR radio/CD player with an Alpine stereo
Tonyrec
Hi all,
I have just removed the standard XS Land Rover stereo from our 2012 model 110. There are two plugs (one brown and one grey) in the vehicle loom. I presume that these are the ISO connectors?
I purchased a take out Alpine stereo from a 2014 model Defender and it comes with a short lead. One end slots into the radio itself and the other end is a large grey plug.
Does anyone know what connector lead I will need to connect this Grey plug to the two vehicle connectors?
I have searched many web pages and cannot identify the one that i need.
Post #330243 11th May 2014 2:45pm
Sounds like your LR is ISO connectors but the HU specific to the 2012 on wiring that was non ISO.
Your Defender must be just before the change.
There are adapters that you can use. Thumbs Up
Post #330260 11th May 2014 3:40pm
Tonyrec
Hi,
I thought that the whole point of the ISO was to be able to fit an aftermarket HU?
Do you know which adapter lead that I should use as I can't find one. I can find leads that go the other way but not the one that I want.
Regards
Post #330264 11th May 2014 3:52pm
Wangers
United Kingdom 1995 Defender 110 300 Tdi CSW Aintree Green
Both of the little ones fir into the one larger one. Ive got '96 110 with 2 plugs, and they fitted straight into the cable that came with the alpine (from LRI). So not 2 seperate to go into but 2 into one. Without seeing yours though hard to confirm.
Post #330269 11th May 2014 3:55pm
The issue is you have a non ISO HU, that is how I am reading this.
From the info you have given the LR is ISO. So, what is the connectors of the HU?
I'm assuming different for you to post here.
The issue is going to be as you say the connectors are one way.
If you can snap a photo that'd be very helpful.
Post #330271 11th May 2014 3:59pm
Tonyrec
I have 2 photos of the connectors........how do i post them or can I email them to you?
Post #330273 11th May 2014 4:04pm
Click reply, then choose photo.
Once uploaded click the photo in the little box it appears in and it will appear in you post which you then submit.
Known as thread upload.
Post #330276 11th May 2014 4:06pm
Tonyrec
Standard car radio loom plugs
Large connector block on Alpine Stereo
Post #330277 11th May 2014 4:10pm
Tonyrec
Hope that the two photos help
Post #330278 11th May 2014 4:11pm
Excellent. Thumbs Up Just have my tea and I'll come back to this thread soon. Thumbs Up
Post #330288 11th May 2014 4:21pm
Right, two options;
Either snip off the plug on the HU and fit this: http://www.ebay.co.uk/itm/16-Pin-Female-IS...3ccb41c0c9
Which would solve your problem, may seem daunting but if everything is checked and matches it's job done.
Just check, check and check again all is correct.
Wiring diagrams are readily available online.
This method obviously means the plug on there now is obsolete, but for your use I doubt you will ever want or need it.
Option two;
Buy this: http://www.nexxia.co.uk/product.asp?s=Harn...=PC2-117-4
Which is the proper loom adaptor, plug the HU's connector into the loom adaptor thus leaving your HU's original plug and wiring in-tact. You will then be left with a male plug on the HU side that is ISO and the same on the LR side.
Purchase the above female plug and snip off the male end on the newly acquired loom adaptor and then your sorted.
Latter option is a bit more complicated but what I would probably do to avoid altering the HU or LR wiring as standard.
So from the HU you should have the following plugs:
Female HU - male loom connector (loom adaptor) female ISO to LR male ISO plugs.
Both the above options will require some hard wiring, it's the only way.
Thumbs Up
Post #330294 11th May 2014 4:53pm
If you need to ID the HU wires someone on here will like be able to get that info for you.
The wires should be colour coded though anyway.
Post #330295 11th May 2014 4:54pm
If you go for the loom adaptor as it and the LR are ISO and the LR specific plug is factory wired the ISO female plug wiring should just be a simple co our match to the LR's ISO plug wiring.
Just check it though, especially the power feeds and earth etc which is the grey plug on the Landy.
Thumbs Up
Hope that helps, took a while to type. Laughing
Post #330298 11th May 2014 5:01pm
Tonyrec
Many thanks for the detailed reply, appreciate it. Thumbs Up
Post #330300 11th May 2014 5:02pm
Welcome, just take your time and all should be good. Thumbs Up
You could have saved yourself all this though just by going for an aftermarket non LR radio. Wink
Never mind, it will work out. Thumbs Up
Post #330302 11th May 2014 5:04pm
