Home > Puma (Tdci) > Work to be done. |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 |
Hello Frenchy90
1. The over revving and then limp mode can be resolved by replacing clutch switch or fuel rail pressure sensor? Not sure about the above question. 2. Clutch rattle when in neutral and clutch pedal out getting louder with time can be resolved by replacing the clutch plate and checking propshafts? I have had the dreaded clutch rattle, and this was resolved by having a new one fitted, which in my case was under warranty, http://www.defender2.net/forum/topic12575.html Hope you get sorted out. Cheers Keith |
11th May 2014 10:18am |
Frenchy90 Member Since: 17 Apr 2013 Location: Surrey Posts: 29 |
Thanks Keith for clarifying the clutch issue. Unfortunately it is coming out of my pocket but it needs doing all the same.
11th May 2014 12:09pm |
