Home > Puma (Tdci) > Transfer Box Oil
Phil_D
Transfer Box Oil
I've just got myself an '08 110 DCPU which I'm going to service. I have a copy of the workshop manual but mysteriously it doesn't specify what type or quantity of oil I need for the transfer box. Does anyone have the details to hand?
Thanks,
Phil.
Post #329601 9th May 2014 10:40am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Ashcrofts said EP90 when I asked this question last week
Post #329612 9th May 2014 11:51am
Phil_D
Thanks, do you know what quantity?
Phil.
Post #329613 9th May 2014 11:58am
shaggydog
Fill it up till its coming out the top filler plug.
About 2.8ish liters. I usually buy 3 bottles from halfords and then have some spare to top up the axles Thumbs Up
Post #329615 9th May 2014 12:01pm
Phil_D
Halfords has EP80W/90 GL-4 and GL-5: which one should I use?
Thanks,
Phil.
Post #329620 9th May 2014 12:17pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
http://www.commaoil.com/products
put your details into their, will give the right quantities and grades.
As for the PUMA box, I'm pretty sure I've read that you shouldn't fill to the filler plug level like you do with the older trucks, so be careful
Post #329624 9th May 2014 12:23pm
Phil_D
Ah, so Comma recommends GL-4 for the axles and SX75W-90 GL-5 for the transfer box. I don't know the difference between GL-4 and GL-5 oils so I don't understand the significance. Why on earth doesn't Land Rover specify this in the workshop manual?
On the quantity point, I know the main gearbox isn't 'fill to level of plug' (it's 2.4ltrs dry and 2.2ltrs refill). The post above suggests the transfer box is 'fill to level of plug'.
Phil.
Post #329629 9th May 2014 12:47pm
shaggydog
Diablo- Think that only applys to the Gearboxes not the transfer box but i could be incorrect there I'm sure someone will correct me!
Post #329633 9th May 2014 12:55pm
grumpy old git
Phil.
AFAIK if there are bronze bushes in the diffs GL5 will eat them, whereas the GL4 won't. The SX75 is a synthetic I think. The use of GL4 or 5 is well debated when it comes to LR.
Post #329649 9th May 2014 1:36pm
MartinK
Refill to the level plug (2.4 litres). I used Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil (was Silkolene SYN 5 75w-90) - this one's GL5.
Tightening Torques:
Transfer Box Filler: 30nm
Transfer Box Drain Plug: 30nm.
Manual says "API GL4 or GL5, MIL-L-2105 or MIL-L-2105B" Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #329653 9th May 2014 1:48pm
Phil_D
Martin, hello, I just found another very helpful post by you about this. I copied your list of oils and checked the Opie website:
Castrol Magnatec 5W-30 A1 Fully Synthetic Engine Oil – 8 Litres
Castrol Axle EPX 80W-90 – 5 Litres
Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil – 3 Litres (Transfer Box, needs 2.3l)
Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF – 3 Litres (Gearbox needs 2.4l)
It comes to £167.82, can that be right?
Phil.
Post #329655 9th May 2014 1:54pm
MartinK
yep - it's not cheap Shocked Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #329657 9th May 2014 1:56pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
I read somewhere you must nit fill it up till it comes out. I must only hold 2.2litres...???
What does the manual say?
Post #329665 9th May 2014 2:17pm
Phil_D
My copy of the workshop manual does not contain any information about the type or quantity of oil required for the transfer box. I saw a post by Martin which (I think) explains that the transfer box is to be filled to the level of the plug and that takes about 2.4ltrs.
In relation to the main gearbox, the workshop manual says capacity is 2.4ltrs from dry and 2.2ltrs refill. The main gearbox is to be filled or refilled with a measured quantity, not simply to the level of the plug.
Phil.
Post #329668 9th May 2014 2:25pm
zone30
Found it: 2.3 litres: top of page 731
Post #329669 9th May 2014 2:31pm
