Home > My Defender > DarthFender TD5 110
Page 10 of 16 <123 ... 91011 ... 141516>
Jambo
[quote
Flip key
http://www.defender2.net/forum/topic23588.html
or 1 piece?
http://www.defender2.net/forum/topic16546.html
[/quote]
Spot on ! Thumbs Up
Post #329406 8th May 2014 7:09pm
Tiger
Both links above have mini how to's
Post #329407 8th May 2014 7:09pm
excossack
You bad person Very Happy ...Posting pics on how you've done your headlining..Thats another job on my ever growing todo list
My headlining (maybe like yours) is getting saggy and scuffed from tip runs etc and needs a coat of looking at
Ho hum, More jobs on the list
Cheers for posting the pics of the seat re-trim as well, again another job on the list! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #329413 8th May 2014 7:22pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Where'd you get the MLV from?
Post #329444 8th May 2014 8:28pm
Looks good (photos on previous page) Amp should be okay but make sure nothing else goes under there.
Could do with some washers or something to give a gap between the mounting and Amp.
Remember heat rises.
Looks good though. Thumbs Up
Post #329449 8th May 2014 8:34pm
Tiger
Ebay
http://www.ebay.co.uk/itm/Dodo-Barrier-MLV...1151209513
Need 4 sheets
1 per footwell
1 over the plastic transmission tunnel
1 cut up and used behind fuse box / pedals / lower dash
Post #329451 8th May 2014 8:36pm
g-mack
ive got 10 sheets of it waiting to go in!!! i went for the stuff with the CCF attached! im doing all of the 110 floor with it!. and eventually a wrights of road matt, from Drew not a cheap project this sound proofing! My 109 thread
my youtube channel
Post #329472 8th May 2014 9:02pm
Tiger
It's good stuff though
Post #329481 8th May 2014 9:26pm
Tiger
Forgot to change name, marriage has been a bit rocky for me and Mrs Tiger recently due to shared use of 'Darth'
Post #329550 9th May 2014 7:14am
kipperthedog
Sure it's not using the dining table as a work bench that's to blame? Very Happy Mrs T may have been out....but you took photos!
Post #329555 9th May 2014 7:41am
I'm sure that all will be well again on Saturday, Matt Smile Darren
Post #329556 9th May 2014 7:43am
Tiger
Yep, getting close now. Thumbs Up
Post #329570 9th May 2014 8:36am
Diablo
How much difference does it make to the racket (I know this is subjective).
Mine are currently dampered, awaiting CCF, but haven't got onto the MLV layer yet.
Post #329604 9th May 2014 11:17am
Tiger
Can't really say as I've not tested between layers.
I will have some before and after DB readings though when I take it out next
Post #329608 9th May 2014 11:28am
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
Tiger wrote:
Quote:
keep an eye on that amp, it's going to get really warm jammed in such a well insulated space
Really? it's got loads of breathing space.
that's more space than it looked like it had, should be ok there then Thumbs Up
Post #330227 11th May 2014 1:52pm
