Home > My Defender > DarthFender TD5 110 |
Jambo Member Since: 30 Apr 2014 Location: Sunny somerset Posts: 13 |
[quote
Flip key http://www.defender2.net/forum/topic23588.html or 1 piece? http://www.defender2.net/forum/topic16546.html [/quote] Spot on ! Last edited by Jambo on 8th May 2014 7:26pm. Edited 1 time in total |
8th May 2014 7:09pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Both links above have mini how to's
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
Where'd you get the MLV from?
8th May 2014 8:28pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20559 |
Looks good (photos on previous page) Amp should be okay but make sure nothing else goes under there.
Could do with some washers or something to give a gap between the mounting and Amp. Remember heat rises. Looks good though. |
8th May 2014 8:34pm |
Ebay
http://www.ebay.co.uk/itm/Dodo-Barrier-MLV...1151209513 Need 4 sheets 1 per footwell 1 over the plastic transmission tunnel 1 cut up and used behind fuse box / pedals / lower dash |
8th May 2014 8:36pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
ive got 10 sheets of it waiting to go in!!! i went for the stuff with the CCF attached! im doing all of the 110 floor with it!. and eventually a wrights of road matt, from Drew not a cheap project this sound proofing! My 109 thread
my youtube channel |
8th May 2014 9:02pm |
It's good stuff though
8th May 2014 9:26pm |
Forgot to change name, marriage has been a bit rocky for me and Mrs Tiger recently due to shared use of 'Darth'
9th May 2014 7:14am |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
Sure it's not using the dining table as a work bench that's to blame? Mrs T may have been out....but you took photos!
9th May 2014 7:41am |
I'm sure that all will be well again on Saturday, Matt Darren
9th May 2014 7:43am |
Yep, getting close now.
9th May 2014 8:36am |
How much difference does it make to the racket (I know this is subjective).
Mine are currently dampered, awaiting CCF, but haven't got onto the MLV layer yet. |
9th May 2014 11:17am |
Can't really say as I've not tested between layers.
I will have some before and after DB readings though when I take it out next |
9th May 2014 11:28am |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
that's more space than it looked like it had, should be ok there then |
11th May 2014 1:52pm |
