Home > Maintenance & Modifications > Replace rear quarter window with aluminium.
Cold_n_Wet
Norway
I considering replacing the rear quarter windows with aluminium to make mounting of cables and antennas easier.
has anyone does this before ?
Can replacement metal windows be bought online ? "Rafiki" 2007 110 STW - Rolling rebuild.
Post #328026 3rd May 2014 1:19pm
shaggydog
There are these which are more like guards that go over the windows if that helps?
http://www.vanxtras.co.uk/shop/product/vx2...-van-guard
I made up a new rear quarter panel which I am going to have put onto my 110 to convert it into a USW to do this and make it more secure.
I don't know of any metal versions of the glass insert though. If you took it to your local fabricators they could probably make you up a pair of inserts using the glass as a pattern?
Post #328030 3rd May 2014 1:35pm
theorangebandit
Wouldnt be too hard to achieve simply aqcuire a templte and cut a sheet of metal. Then rivet in place, the or cut so the metal will fit into the window rubber seal
Post #328034 3rd May 2014 1:37pm
Cold_n_Wet
Norway
Pulled the trim of the insides, and there are possibilities to bolt it internally.
Will have a chat with a local workshop.
Glen "Rafiki" 2007 110 STW - Rolling rebuild.
Post #328110 3rd May 2014 6:55pm
