Home > Maintenance & Modifications > Replace rear quarter window with aluminium. |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
There are these which are more like guards that go over the windows if that helps?
http://www.vanxtras.co.uk/shop/product/vx2...-van-guard I made up a new rear quarter panel which I am going to have put onto my 110 to convert it into a USW to do this and make it more secure. I don't know of any metal versions of the glass insert though. If you took it to your local fabricators they could probably make you up a pair of inserts using the glass as a pattern? |
3rd May 2014 1:35pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Wouldnt be too hard to achieve simply aqcuire a templte and cut a sheet of metal. Then rivet in place, the or cut so the metal will fit into the window rubber seal
3rd May 2014 1:37pm |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 244 |
Pulled the trim of the insides, and there are possibilities to bolt it internally.
Will have a chat with a local workshop. Glen "Rafiki" 2007 110 STW - Rolling rebuild. |
3rd May 2014 6:55pm |
