Home > Maintenance & Modifications > Puma water temp gauge function
Page 3 of 3 <123
munch90
no holes as standard , you would need to get a hose adaptor then cut the hose you wanted to fit too
something like this eBay item number: eBay Item No. 131174368994
but in the size you want
Post #327834 2nd May 2014 1:58pm
ericvv
Interesting read, even more if you understand South African as I do Cool , but the core message is there for all.
Seems the Puma even under normal circumstances and not high engine loads operates at already pretty high water temperatures, so risk of it reaching +100�C temps seems pretty high.
http://www.4x4community.co.za/forum/showthread.php?t=122395 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #327841 2nd May 2014 2:16pm
Naks
I regularly see 101C on my coolant temperature, esp when doing 120kmh on a very hot day.
Usually it sits at around 91-93C. --
Post #327852 2nd May 2014 3:43pm
dgardel
Italy
All infos that you need are here!
From the workshop manual
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #327917 2nd May 2014 9:19pm
dgardel
Italy
Ehmmmm Embarassed sorry Ericvv ......
am I late? Rolling with laughter
By the way, all modern engine works closer to 100�C (or little higher than). It is needed for increase the combustion efficiency. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #327918 2nd May 2014 9:21pm
ericvv
Thanks Daniele, had seen that explanation already, yes. But it still does not make me happier, because it means that the gauge needle nicely stays fixed in the middle section until coolant water reaches 115�C, and that seems a bit too high to me.
So still would like to install a VDO gauge which will show the real water temp, and would allow to reduce engine load if I would see the water temp go higher than 100 or 105�C,................ without waiting until the needle flashes to red when the temp reaches a point above 115�C and maybe something pops at the same time. Evil or Very Mad
Right now with the factory set-up the water temp gauge gives us the same visibility on temp as swimming in a mud bath.
Post #327924 2nd May 2014 9:37pm
dgardel
Italy
Hi Ericvv
All modern cars uses the same water gauge strategy, Audi, BMW, Opel, etc.
Also remember that the oil temp is already (very) important.
For example, during the winter when the water reach the "right" temp, the oil may still be cold, causing cavitation on the bearing if you drive at high revs.....
Right "way of driving" is:
1. engine warm-up : up to oil temp reach 70 �C
2. engine normal operations : water T �C from 85 to 110, oil T �C from 90 to 130 (race engines oil reach 150-160 �C normally)
I like the gauges used by MD5 (Mario) forum member:
http://prosportgauges.com/60mm-premium-evo-series.aspx
IID Pro MV License
Post #327931 2nd May 2014 9:52pm
ericvv
I would do something like that, but I do prefer the traditional analog black VDO gauges look. But in the SVX Mario's solution is not possible as the Garmin mount already occupies that place on the dash.
I will see if I can find a specialist here (think I know one) who can install a VDO water temp gauge, and who knows, maybe even a VDO oil temp gauge in the side panel of the black plastic panel left of the center console. I think it can fit nicely there and with my smaller than standard steering wheel, there is enough place left to give good visibility on the gauges.
Eric
This VDO series (Viewline) seems the best to match the Puma instruments (white needles)
52mm water temp gauge with alarm
Sensor for above giving alarm signal at 105�C
52mm oil temp gauge (maybe, vertically under the water temp gauge)
Post #327941 2nd May 2014 10:28pm
landyman37
Now it would be nice to get the tdci gauge redone to use a td5 gauge
Phil
Post #327979 3rd May 2014 9:23am
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
My Puma dash
My set up.
I have an combination oil and water temp gauge from Redarc.
It alarms red and audibly when temp gets over 120 Deg C.
I’m in Australia, with a heavy 110 Puma, so knowing what the engines up to is very important to me.
Post #796141 1st Oct 2019 6:54am
nicam
2015 Defender 110 Puma 2.2 USW Aintree Green
I was once told that the reason that temperature gauge readings were "manipulated" as described was to mask the effect on water temperature of DPF regeneration cycles and the excessive amounts of heat they generate.
The manufacturers don`t want eagle eyed customers reporting "overheating" when they see the gauge rise.
Their attitude must be "Ignorance is Bliss" Don`t drive faster than your angel can fly!
Post #796181 1st Oct 2019 1:21pm
Eduardo
As a sufferer of too maany limp modes I tend to be agree with Eric.
Will be nice to have in the current gauge something between "normal" and "too hot". In fact any time that I suffered a limp mode by temperature, the needle just going direcly to the top without any advice no giving any time to reduce the speed or change th gear to avoid it.
I already solve the problem usind a OBDC reader that gives an audible alarm if the temperature going over 105°C, but the position of the screen is outside the view of the driver, so you cannot see really the temp. The current gauge is already in sight. So why not use it?
Cheers Eduardo
Post #796231 1st Oct 2019 7:03pm
Page 3 of 3 <123
