Home > Maintenance & Modifications > New Bonnet Release Cable
Benzini
United Kingdom 1988 Defender 90 Other HT Bonatti Grey
Hi all,
Few queries for you (I have already searched):
My truck (1988 Defender) currently has no bonnet release cable. I'm wanting to put one on it however, I don't know what this is to order one (the small bit at the end of the cable)
What / where can I order one?
Secondly, there's no bracket in the cab to mount the "puller" end, I've searched however can't seem to find any replacement for it. Ideas?
Post #326997 29th Apr 2014 4:44pm
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
I've just got a new one for mine, think it was about £7, I got it from my local supplier but believe its a Britpat item.
The handle bit is in the cab, left side of clutch pedal, I've not looked under the bonnet and its chucking it down at the moment
Post #327000 29th Apr 2014 4:48pm
Benzini
cheers for the quick reply.
Yeah I've got the new cable mechanism but it didn't come with the small metal bit at the end.
I know where the cable is supposed to go in the cab but there's no bracket for it... I think originally they were spot welded on?
Post #327001 29th Apr 2014 4:50pm
Buz
This is where mine fits near the release mechanism, not sure how you would fix it without the 'nipple'
This is the cab fixing bit
Post #327004 29th Apr 2014 5:01pm
Romadog
C01.225 GRILLE, TOP PANEL & BRACES-CABLE BONNET RELEASE
KIT-BONNET LOCKING
Part number: STC927
Post #327015 29th Apr 2014 5:34pm
Benzini
many thanks, that solves that problem.
Any idea what to do about the bracket though?
Post #327027 29th Apr 2014 6:38pm
Buz
Bolt a piece of angle iron in the place where the original went?
Post #327041 29th Apr 2014 7:09pm
munch90
not sure if you got nipple sorted , you could put a small bolt down though the hole in the bonnet latch lever with small hole drilled through it , pass cable through hole and lightly tighten nut against the cable
you used to be able to buy universal cables with a bracket included
Post #327043 29th Apr 2014 7:15pm
Buz
Same idea you had on the old pushbike for adjusting the brake cables Wink
Post #327044 29th Apr 2014 7:16pm
Benzini
Both good ideas, I'll let you know how I go! Smile
Post #327045 29th Apr 2014 7:16pm
munch90
that's it
Post #327056 29th Apr 2014 7:44pm
landy andy
You could also use the internal section of an electrical chocky block Thumbs Up
Andy
Post #327061 29th Apr 2014 7:55pm
VeeTee
Netherlands
wire cable end stop on flebay Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #327065 29th Apr 2014 8:09pm
Benzini
So I take it I should fabricate something to go off of the large bolts to the left of the clutch pedal.
Also, I can't see anywhere obvious where the cable is supposed to go through the firewall?
Post #327310 30th Apr 2014 6:48pm
Buz
Looks like mine is riveted or welded in place. The cable goes through to the left of the clutch pedal
[/img]
Post #327338 30th Apr 2014 7:14pm
