![]() | Home > Wheels & Tyres > BFG KM2 tyre size on standard truck |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17612 ![]() ![]() ![]() |
I have, with no problems whatsoever (285/75 x 16 BFG MK2 Muds on Boosts).
You will find it advantageous to fit 30mm spacers to improve the turning circle, and the outside of the vehicle will get covered in crud, but it works fine. Many here will tell you it can't/shouldn't/mustn't be done, and it is true that a Boost is narrower than the manufacturer's recommended minimum width for a 285, but it fits fine. Mine have done over 100k miles with no dramas at all. |
tony110dc Member Since: 18 Apr 2014 Location: Northumberland Posts: 9 ![]() ![]() ![]() |
Thanks for that, I'm going to order 6 today, they are going on 7"X16" Blindo Alloys, was toying with the idea of 30mm spacers, any particular make you could recomend?
I used Rakeway spacers, since I think they are the best. There are many available nowadays of rather indistinct origins, so I would always specifically choose a good branded product direct from source. They're also pretty good value.
If you're buying the Blindos I think that you can get an offset equivalent to a Boost on 30mm anyway, in which case you may not need spacers at all. PS - Why 6, not the more predictable 5? |
Yeah i think my blindo's have the off-set already, Ive do a bit overland, so one spare on the back & one on the roof (just when im on a trip)
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1725 ![]() ![]() |
Tony ive just put 285's on evo course dakars (like blindo with the same offset) and had spacers fitted allready. Im about to take the spacers off as there offset allready. Thought i'd post as might save you a bit of money on spacers.
![]() ![]() Click image to enlarge Defender puma dormobile camper |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
I have 255/85s Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
255/85s would and will be my next choice! My 109 thread
my youtube channel |
