Home > Puma (Tdci) > Wiper stripped.
RED-DOT
Wiper stripped.
Hi, my N/S wiper arm has stopped working but the other one is fine. Will the whole dash have to be dismantled or can the N/S be removed only?
Anyone got a link to dash removal?
TIA. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #326370 27th Apr 2014 9:59am
leeds
Before dismantling the dash have you checked the 'corrugated/spline' wheel on the outside?
Remove wipers and check if the splined wheel is operational. If the splined wheel rotates properly with wiper motor on then it could be something as simple as wear on the splines. That is a straightforward repair if that is the case.
Brendan
Post #326382 27th Apr 2014 10:27am
RED-DOT
No movement on shaft to wiper arm. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #326466 27th Apr 2014 5:11pm
mk1collector
The wiper wheel box gear is probably stripped so on a puma dash a big chunk will have to be at least pulled forward
Post #326543 27th Apr 2014 8:25pm
Michael Brindley
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Mine went on 2007 puma.Put it down to trying to use wipers when windscreen was frozen.Had to change wiper spindle and cable.Cable has thread on it which rotates wiper spindle,both had striped.Managed just to loosten dash and pull foreward few inches.Big job to remove dash.It was trickey but can be done.Mobile mechanic friend helped said it reminded him of very old mini wiper system.
Post #326554 27th Apr 2014 8:59pm
JWL
IIRC it is exactly like the old Mini just slightly different in length, I can't remember which way
Post #326559 27th Apr 2014 9:18pm
