Home > Technical > What's this leaking |
Is it oil or diesel? Your picture shows the fuel pressure regulator, which is well known for leaking. Darren
27th Apr 2014 8:34am |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 |
It's oil. But coming from that area
27th Apr 2014 8:36am |
That'll be your fuel pressure regulator, you can get service kits with the "bowl"(pressure valve) to repair for £40 or less off t'internet. It is quite a simple job to do especially when you can see it. Also.take a look to see if there isn't a leak from the back of the rocker cover, there is a section on the very back with a semi-circle part that is prone to letting oil out, either a new seal or use some gasket seal like Blue Hylomar to sort that one out.
27th Apr 2014 8:40am |
In that case, it's possibly the half moon shaped gasket at the back of the rocker cover. Darren
27th Apr 2014 8:41am |
