![]() | Home > Technical > What's this leaking |
Is it oil or diesel? Your picture shows the fuel pressure regulator, which is well known for leaking. Darren
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
It's oil. But coming from that area
That'll be your fuel pressure regulator, you can get service kits with the "bowl"(pressure valve) to repair for £40 or less off t'internet. It is quite a simple job to do especially when you can see it. Also.take a look to see if there isn't a leak from the back of the rocker cover, there is a section on the very back with a semi-circle part that is prone to letting oil out, either a new seal or use some gasket seal like Blue Hylomar to sort that one out.
In that case, it's possibly the half moon shaped gasket at the back of the rocker cover. Darren
