Home > Puma (Tdci) > Torque settings
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Torque settings
Hi All,
I wonder if anyone out there has a torque setting for the filler plug on the gearbox and transfer (NOT the drain plug as the manual states the torque for this).
Also any suggestions for the axle drain/filler plug torque (if any) or is it 'chamfered'.
Welcome any suggestions.
On another matter, The 'original' radio has a clock facility which sometimes the clock tells the time and sometimes the screen says 'No Clock' - There is nothing in the manual about this? Any knowledge on this?
Joe
'El Pepe Flamenco' JLS
'El Pepe Flamenco'
Post #32628 20th May 2010 10:50am
Bodsy
Transmission
Install the transmission filler plug and clean any oil residue from the surrounding area.
Tighten to 35 Nm (26 lb.ft).
Transfer
Install the transfer case filler plug and clean any oil residue from the surrounding area.
Tighten to 30 Nm (22 lb.ft).
For the 2.4L Diesel from GTR. Thumbs Up Over on D3
Post #32629 20th May 2010 11:19am
CapeLandy
South Africa
One thing to check for - both my front and rear diff filler plug threads were nackered from the factory.
Have a close look - I had to file mine with a thread file to get a decent fit.
Post #32646 20th May 2010 2:29pm
jlerra
Torque settings
Thanks folks for your prompt reply.
Very much appreciated.
Joe
'El Pepe Flamenco'
Post #32650 20th May 2010 3:46pm
mse
Shocked there is a torque for the filler plugs Exclamation
Whats wrong with its done up, tight but not too tight Question Thumbs Up Mike
Post #32673 20th May 2010 9:13pm
K9F
Torque Settings General Rules:
Upto 8mm - Quarter of a white knuckle.
9mm - 18mm - Half a white knuckle.
19mm - 30mm - Full white knuckle.
31mm - 40mm - Slight 'click' in wrist is heard.
41m - 57mm - Veins on neck to stand out like head is going to explode.
58mm upwards - You should jump up and down on the ratchet handle at least 6 times, if carried out by hand bloodcells in eyes must rupture and you need to go lie down for at least 20 minutes to recover composure.
Rolling with laughter Dog Thumbs Up Dog Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32676 20th May 2010 9:27pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
That works for me Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #32678 20th May 2010 9:29pm
K9F
On the last two settings don't be surprised if you have to do a 'trolley check' for conkers even worse if you've had a night on the cider before.
Rolling with laughter Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32680 20th May 2010 9:36pm
