Home > Technical > Low Range Warning Light !
chalky
Just scrutineering the dash layout etc ! Noticed that there is a Low Box warning light on the dash where the rev counter is in thr black bit where the clock should be ?
Any way having used it in low box and Diff Lock that particular light has never illuminated ?
So where is the Warning light for Low Box and is mine U/S ? DEFENDER XS CSW 08 TONGA GREEN
Post #2445 17th Jun 2008 11:32am
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Mine has never lit up so assume that its not there on the defender even though the dash allows for it Exclamation Exclamation
Post #2462 18th Jun 2008 12:12pm
TJ101
Working from memory,, no lamp for low gears, only diff lock !!
Had a couple of occasions, where i had to use reverse and lock to lock, for the diff lock to dis-engage !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #2487 19th Jun 2008 8:08pm
jst
the light is there and on the first ones out of the factory it was connected up and came on to show low range
they just gave up connecting it up on the later models i expect you could find a way to reconnect it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #3257 20th Aug 2008 6:17pm
mse
Its actually part of other model dash clocks.
I would be interested in connecting it up (only as i think it would be cool). Mike
Post #3259 20th Aug 2008 6:18pm
jst
correct - D3, some RRS
possibly as some D3 owners may struggle to work out why they can only go 40mph!! (note i said some note all before anyone gets upset) Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #3262 20th Aug 2008 6:24pm
mse
Laughing Only the D3 owners Rolling with laughter Mike
Post #3263 20th Aug 2008 6:55pm
