Home > Technical > Low Range Warning Light ! |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 |
Just scrutineering the dash layout etc ! Noticed that there is a Low Box warning light on the dash where the rev counter is in thr black bit where the clock should be ?
Any way having used it in low box and Diff Lock that particular light has never illuminated ? So where is the Warning light for Low Box and is mine U/S ? DEFENDER XS CSW 08 TONGA GREEN |
17th Jun 2008 10:32am |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Working from memory,, no lamp for low gears, only diff lock !!
Had a couple of occasions, where i had to use reverse and lock to lock, for the diff lock to dis-engage !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
19th Jun 2008 7:08pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8013 |
the light is there and on the first ones out of the factory it was connected up and came on to show low range
they just gave up connecting it up on the later models i expect you could find a way to reconnect it. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th Aug 2008 5:17pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Its actually part of other model dash clocks.
I would be interested in connecting it up (only as i think it would be cool). Mike |
20th Aug 2008 5:18pm |
correct - D3, some RRS
possibly as some D3 owners may struggle to work out why they can only go 40mph!! (note i said some note all before anyone gets upset) Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th Aug 2008 5:24pm |
Only the D3 owners Mike |
20th Aug 2008 5:55pm |
