Home > Puma (Tdci) > New ABS kit Fix
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
New ABS kit Fix
Hi Guys. I do not have ABS in my puma 2009 CSW. Is it possible to fix a new one from the scratch together with traction control? If so how much would it cost?.
Cheers. Appreciate!
Kind regards,
Diluk
Post #324818 20th Apr 2014 7:40am
it would probably be easier to change your vehicle. you have the AB controller, the ecu to re-map, the physical wheel sensors etc ... if it's purely for traction, fit a LSD or locker
Post #324820 20th Apr 2014 7:44am
K9F
The modulator alone would be likely to cost over £1,000 from new. In my opinion consider part exchanging your truck for a higher specification one. Dependant on availability in your neck of the woods and demand for Defenders it may not cost you much more than fitting a complete system and it'll save you a lot of work and potential hassle to boot.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #324821 20th Apr 2014 7:47am
dilukabey
Many thanks for bpman and k9f for the prompt replies. My main purpose would be to install the ABS as I have had number of long drag braking scenarios. So just for some extra safety I thought of fixing one. But as both you suggested the better option would be to change the whole truck. Cheers!
Kind regards,
Diluk
Post #324823 20th Apr 2014 8:05am
