Home > Puma (Tdci) > New ABS kit Fix |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 |
Hi Guys. I do not have ABS in my puma 2009 CSW. Is it possible to fix a new one from the scratch together with traction control? If so how much would it cost?.
Cheers. Appreciate! Kind regards, Diluk |
20th Apr 2014 7:40am |
The modulator alone would be likely to cost over £1,000 from new. In my opinion consider part exchanging your truck for a higher specification one. Dependant on availability in your neck of the woods and demand for Defenders it may not cost you much more than fitting a complete system and it'll save you a lot of work and potential hassle to boot.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th Apr 2014 7:47am |
Many thanks for bpman and k9f for the prompt replies. My main purpose would be to install the ABS as I have had number of long drag braking scenarios. So just for some extra safety I thought of fixing one. But as both you suggested the better option would be to change the whole truck. Cheers!
20th Apr 2014 8:05am |
