Home > Puma (Tdci) > How much play in turbo spindle?
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi .. I've been busy changing the turbo gasket this morning. Whilst it was all apart I felt some side to side play in the turbo spindle. Is this normal? 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #324696 19th Apr 2014 1:48pm
barbel jim
There should be some, but minimal. More than likely its fine, not sure how to describe the expected play Confused
Post #324843 20th Apr 2014 9:52am
martinfiattech
Have a good look down the intake if all the blades look ok and corners are sharp all`s well you will get a small amount of end float its normal.
If you really want to check it remove the output hose on the pressure side or where access permits give everything a wipe rev it up a few times to purge system.
Hold a sheet of white paper in front of output pipe about six niches away or so, rev it to 3000 rpm for a few seconds if your turbos passing excessive oil it will be blasted all over the paper, no oil good turbo if it looks like its been shot by a spray can turbo nackard easy and cheap test may put engine management light on for boost fault.
Post #324963 20th Apr 2014 8:18pm
