Home > My Defender > g-macks 110 300 tdi thread |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
thanks Gum, its slowly transforming. My 109 thread
my youtube channel |
8th Apr 2014 7:40pm |
managed to get front springs on today. standard yellow yellow with isolate-rs top and bottom. havent drove it enough to say if its any better yet! but i think it may be a little smoother! sure removing HD ones from the back will make a bigger difference.
new spring with isolaters Click image to enlarge Click image to enlarge After Click image to enlarge My 109 thread my youtube channel |
11th Apr 2014 7:11pm |
Rear standard springs went on today, I'm hoping they will drop a little as they settle.
Doesn't look any lower than the old +2s excuse the psychedelic colour!! Click image to enlarge My 109 thread my youtube channel |
15th Apr 2014 2:30pm |
after using the motor all day today over the horrendously pot holed roads on my commute, i must say i'm underwhelmed by the "improvements" gained by going to standard softer springs with isolators top and bottom!!!
maybe the poly bushes are not helping either, also gonna check tyre pressures and lower them if to high. My 109 thread my youtube channel |
16th Apr 2014 9:11pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Have you changed the dampers? IMHO they will make the real improvement for ride if you use a quality brand BM52
16th Apr 2014 9:28pm |
i haven't BM, its got yellow supergaz on! only covered 30k with them, they were on when i got it. eventually i will replace with koni's but im a bit hesitant to spend the cash if once again it will only be a minor improvement. My 109 thread
my youtube channel Last edited by g-mack on 11th Jul 2014 2:05pm. Edited 1 time in total |
16th Apr 2014 9:51pm |
Koni will make a big improvement in my opinion BM52
16th Apr 2014 9:59pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I'm surprised, the difference to mine was instantly noticeable. I'm still running on procomp shocks which might be the difference?
I too am aiming to fit some koni shocks but once I have got my other headaches out the way first. What tyres and pressures are you running and what do you usually carry? I am running General Grabber at2's at 40 front and 45 rear and find it a good trade off between comfort and load carrying capability. |
16th Apr 2014 10:25pm |
tyres are bfg ATs 38 psi all round but gonna play with that! i wonder if the supergaz are quite firm. when i was changing the springs i couldn.t compress them at all by hand! ive got a boot full of tools that bounce and rattle around! i think i might go to work tomorrow with an empty boot and see if its any better. i think the tools banging around on the bumps might be making me think its the suspension banging! My 109 thread
16th Apr 2014 10:31pm |
You should be able to compress the shocks by hand.
When I took mine out I made sure I compressed them all the way to the bottom and released to ensure they were nice and smooth and free. If you cant do this I would suspect something wrong with them as they should be free. Don't get me wrong its not a one handed easy compress but should just be able to lean on it and it compress. |
16th Apr 2014 10:43pm |
stand on the front bumper and bounce...it should move up and down a coule of inches a least. Also look at the hand book as I think your front tyres should be around 28?
see chart here http://www.defender2.net/forum/topic24802....=pressures BM52 |
16th Apr 2014 10:54pm |
Aquarius0 Member Since: 21 Apr 2014 Location: Rumia Posts: 14 |
what are you still planning to equip on your landy?
21st Apr 2014 11:21am |
EddieB Member Since: 08 Apr 2013 Location: Durham Posts: 57 |
If it helps, I have yellow supergaz on my 110, and it's very firm. Being an ex tree surgeon's hicap they were probably needed but it can be really harsh over the slightest bump.
21st Apr 2014 11:31am |
thanks eddie, suppose its another thing on the long list of things to change My 109 thread
21st Apr 2014 12:01pm |
