Home > Maintenance & Modifications > CSK DRL BUMPERS |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4646 |
Has anyone fitted one of the CSK DRL bumpers? I'm thinking of getting one so I just wanted to hear what your thoughts on them are. 1982 88" 2.25 diesel
15th Apr 2014 3:20pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5109 |
As an Alternative I have fitted this one very pleased with the result
http://www.outbound4x4.co.uk/shop/exterior...drl-bumper Or if you fancy fitting the DLR's yourself they do a kit http://www.outbound4x4.co.uk/shop/exterior...fender-drl The DLR's work well switch on as soon as the engine is started dim to 50% brightness when side lights are switched on so as not dazzle on coming drivers at night. And they have a see you home feature once the engine is switched off |
15th Apr 2014 3:37pm |
Thank you. Always good to hear feedback. I'm just interested in any DRL BUMPER that is easily wired and does the job.
Does powder coated mean that it will look as rusty as the genuine bumper after a short time? 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
15th Apr 2014 3:56pm |
Definitely worth thinking about. Thanks 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
15th Apr 2014 3:58pm |
Took me twenty minutes to fit the outbound electrics, only four conections. Even less to fit the bumper. I bought the kit and had my stainless steel bumper drilled by a machine shop. Stainless steel bumper no more rust!!! |
15th Apr 2014 4:57pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2101 |
for Outbound .. works really well and looks great. Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
15th Apr 2014 5:07pm |
If the DRL's stay on when the sidelights are switched on -albeit dimming to 50%-will that not put more strain on the relayless light switch? 1982 88" 2.25 diesel
15th Apr 2014 5:12pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1720 |
David Whittaker on here just fitted a new one to his recently from CSK and I think he was pleased.
Ive just taken off an old CSK one (no fault of its own its on my mates 90 now as i just wanted a plain galvanised bumper) The quality seemed very nice and the powdercoating as good as you'll get. I think there very nicely made and good for the price if thats what your after. So i'd recommend them Defender puma dormobile camper |
15th Apr 2014 5:31pm |
As far as I am aware it is a legal requirement for DLR's to to dim at night any that do not could get you in trouble with the police and the MOT Our rule 226 is this use any lights in a way which would dazzle or cause discomfort to other road users, including pedestrians, cyclists and horse riders And also EEC regulation 48 adopted by UK law vehicles first used on or after 1 April 1987 or functionally dedicated daytime running lamps to be equipped with a dim-dip device. Any of the bumpers fitted with DLR's or any kits that do not follow this may get you into trouble not only with th police and testers but irate motorists who you dazzle. DLR's are very bright so they can be see in daylight so are very very bright at night. |
15th Apr 2014 6:05pm |
I can confirm that the Outbound DRLs do 'dip' when the sides or mains come on, and that they come back to full brightness when the mains and sides are turned off.
Also that the DRLs come on a few seconds after the engine starts, and then stay on for about 90secs after the engine is turned off. The whole thing was easy to fit - so much so even I could do it ! Outbound supplied all the needed cables, fuses and relays, the power is taken straight from the battery through the provided conenctions. there is no load on the vehicle relays or switches at all. I was caught out as I found the lights were still on after I had turned off the engine and refitted the wires 3 times before I read the little bit on the bottom that said that .... the lights stayed on after turning off the engine ... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
15th Apr 2014 7:30pm |
You can if so wish wire the positive to an ignition feed rather than direct to the battery that way the lights will go out as soon as the ignition is switched off. The Outbound DLRs work off a control unit that switches the lights on at 13.5 volts IE when the engine is switched on and the alternator is running, that is why there is a five second delay with the light coming on.. The dim dip feature is achieved by connecting a wire to the positive feed of a sidelight and when the sidelights are switched on a 12V supply is sent to the control unit which reduced the power to the DLR's by 50%. The DLRs will continue to illuminate for short time after switching off the engine, but as soon as the battery voltage drops with no alternator feed they will switch off usually about 60 to 90 seconds. |
15th Apr 2014 8:01pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2751 |
Indeed I did, and can't recommend highly enough!
See here : http://www.defender2.net/forum/topic25621.html Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
15th Apr 2014 11:07pm |
