Home > Puma (Tdci) > Odd noise
Dickie
Odd noise
Help
When I switch off after a second or two there is a strange rattle coming from the near side of the engine bay, any answers please
Post #323401 12th Apr 2014 10:11pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
EGR cleaning itself? 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #323403 12th Apr 2014 10:20pm
K9F
http://www.defender2.net/forum/topic12553.html?highlight=egr
http://www.defender2.net/forum/topic9641.html?highlight=egr
http://www.defender2.net/forum/topic5841.html?highlight=egr
http://www.defender2.net/forum/topic7356.html?highlight=egr If you go through life with your head in the sand....all people will see is an ar5e!!
Post #323404 12th Apr 2014 10:54pm
Naks
If it's not the 5x chuka-chuka from the EGR self-cleaning, it could be the death rattle of your clutch --
Post #323413 13th Apr 2014 7:54am
Dickie
Sounds like the EGR Vv also doing it on the move mainly when backing off coming up to junctions.
Is it just a clean or a replacement job required?
Cheers for the advice.
Post #325236 22nd Apr 2014 8:37am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi Dickie
welcome to the forum
its the normal self cleaning routine for the EGR valve and doesn't need any intervention from you at the moment.
if it is excesive then you could try running a tank of higher quality fuel (BP ultra or simmilar) that made mine quieter for a time, or you could have a remap that will keep the EGR closed (as well as bost your driving power)
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #325250 22nd Apr 2014 9:11am
Dickie
Hi
It can't be normal as this is a 57 plate with 52k on it and only just stared happening.
Post #325278 22nd Apr 2014 10:46am
K9F
It is a common occurence as detailed in previous posts and links. If you don't fancy living with it or trying any of the suggestions take it to your local independant and/or dealer and seek expert advice, initially all it will cost is a little time and a little diesel.
Probably ensued by a suggestion you need a new EGR valve. You could try cleaning it if you have the inclination.
http://www.defender2.net/forum/topic2227.h...r+cleaning
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #325280 22nd Apr 2014 11:12am
wyvern
Dickie wrote:
Hi
Hi Dickie
as K9F says ... try the fuel first and then if your still worried take it to bits and see if it needs cleaning.
Mine is an 07 plate with about 98k and it started scratching when cleaning after about 60k .. it never gave me any issues and I used hige quality fuel in about 1 tank in 6 that made a differance - however it's much better after a BAS remap that closed the EGR all the time (ie - silent!)
There are many posts on the forum on this subject if you need more convincing - just search EGR and see what comes up!
hope that helps
Post #325293 22nd Apr 2014 12:55pm
