Home > Td5 > Coolant system pressure "vs" gagging at high rotat
fmrodrigues
Portugal
Hello,
This is my first time at the forum.
My name is Frederico and I’m from Portugal.
I have a second hand 2000 110 TD5 SW, with 180.000 KM, without any historical maintenance records, so I have no idea what problems it could have had.
Some time ago, when I was driving, for a few instants it suddenly lost power.
It happened a second time and this time I was able to see the temperature gauge going, momentarily, to the red.
When I stopped I found out there was, more or less, 1 liter missing from the coolant expansion.
(I don’t know if this quantity was enough to justify the overheating)
After refilling, everything seemed normal but when I stopped there was water leaking from the back of the head - Plug Core 37D2260L.
(2 photos)
After replacing and checking the coolant level, I went for a short ride.
At high rotation there was some gagging.
After stopping I took the coolant expansion cap off.
(2 videos)
There was a lot pressure inside and the water rose to the opening level.
I don’t know which should be the correct pressure value inside the coolant system, but I tested it for exhaust gas and the result was negative.
(1 video)
I’m not convinced everything is OK, the gagging at high rotation is still there and the coolant system is always with a lot of pressure in.
Can someone help?
Thanks in advanced.
Frederico
Post #322375 8th Apr 2014 12:55pm
landy andy
The high temp reading and loss of power is not a rare Td5 problem. It is often cured by running a new earth to the ECM platform direct from the battery.
Andy
Post #322457 8th Apr 2014 6:15pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
the temp gague flicks to the red and the goes to blue?
the coolant is boiling in the plastic reseviour?
your water pump is not working. either the blades have rusted away or the pump bearing has failed and is not turning so the coolant is not moving as fast as it should be. The defender has migrated, leaving the owner behind.
Post #323072 11th Apr 2014 12:41pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I have had this problem & it was the head gasket /cracked head which is a common problem with Td5s
Post #323117 11th Apr 2014 4:32pm
fmrodrigues
Portugal
Here goes a photo from the water pump.
Achuakh was right, the blades were completely rusted away.
I just hope the overheating didn’t damage the head gasket!
I will keep you informed.
Frederico
Post #332246 20th May 2014 10:35am
fmrodrigues
Portugal
Here goes the photo.
Frederico
Post #332247 20th May 2014 10:38am
fmrodrigues
Portugal
Post #332249 20th May 2014 10:40am
achuakh
Well, at least you still have 5 blades there.
I had two left. The defender has migrated, leaving the owner behind.
Post #332486 21st May 2014 6:24am
fmrodrigues
Portugal
Looking to the elbow, the antifreeze also wasn’t any good!
Frederico
Post #332539 21st May 2014 2:32pm
Looks like they used caustic soada instead of antifreeze! Shocked
Post #332699 22nd May 2014 6:53am
