Home > Off Topic > Dash camera
Page 2 of 4 <1234>
Skippy R
United Kingdom 1998 Defender 90 300 Tdi SW Chawton White
Cheers for all the replies, got some reading to do now then ! Dave
98 'S' 90 300Tdi (sold)
07 D3 HSE (now sold)
1993 Scania 143 450 (should have kept that ! )
Post #322262 7th Apr 2014 9:44pm
Egghead
A good video review can help no end too... Techmoan on Youtube reviews a few and has some good approaches to explain what is good and what is not about some cameras. (For example: The best £100 Action Camera - TCL SVC200)
I bought a cheap one from Ebay that was a replacement rear view mirror (it clipped over the existing mirror). It wasn't suitable because
  • it was huge and the Defender mirror is not the sturdiest support for something big and heavy.
  • It also prevented the sun visors being deployed Sad
  • The heating element wires in the front windscreen caused the video to be out of focus despite many efforts to correct it.
  • My cigarette lighter socket permanently supplied power to it so I had to manually turn it on and off each time!
Despite the quoted HD resolution I couldn't make out the number plates on vehicles clearly enough when playing back video. I will look at only the very best quality equipment for the next camera I choose, and I have heard good comments about Blackvue cameras, although I quite like the look of the Roadhawk that Lorryman posted.
It is also another (valuable) bit of kit in the vehicle that appeals to the light fingered c Censored s in this world.
Post #322287 7th Apr 2014 11:15pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I made a sample from my cam today to give an idea of quality. Mix of direct sun light, shade and normal overcast. Audio quality is okay considering the vehicle Laughing .. camera fixed to the bottom of the window. Very little blur if any in day light when I freeze a frame so I can read number plates okay.
&hd=1
Post #322472 8th Apr 2014 6:43pm
Tiger
Well done on getting Radio2 in Snowdonia Thumbs Up
Post #322485 8th Apr 2014 7:01pm
GUM97
I was at that Petrol station only yesterday! (In Penrhydeudreth?) Shiny bonnet too! An engine to TDi for!
Post #322510 8th Apr 2014 7:35pm
keith
A few reasons you would want to fit a dash camera
Post #325446 22nd Apr 2014 7:45pm
Surrey Rover
keith wrote:
There shouldn't be anything wrong with a GO-PRO
I was about to buy one for this very purpose . Bonus being their tiny size , picture quality and ability to fix on the roof rack .
I wouldn’t. As the owner of a GoPro I really rate them, but not as a dash cam. For a start if you stick it to the roof rack you're bound to forget it at some point and leave it there for some scroat to half inch. The battery life really isn’t that good which means if your on a long journey your talking about changing batteries mid trip and even if you do have it on the inside with a constant charge the file looping isn’t set up like a dash cam, which means it won’t delete older files unless it’s constantly powered, even with the keys out.
IMO you want something on the inside that’s wired in and you can forget about it until you have a smash or some eejit decides to try it on and rolls across your bonnet. Nick
2.2 110 Tipper
Post #325463 22nd Apr 2014 8:14pm
keith
Nick
That's great advice thanks Thumbs Up
Post #325470 22nd Apr 2014 8:23pm
Surrey Rover
I have the Roadhawk, seems a nice bit of kit. I had some powering on issue’s with mine when I first got it but updated firmware resolved that. No issue since and that was probably over 12 months ago. The quality is superb and once it’s in you can forget about it.
Unless your opportunist is having a good poke around they are not immediately obvious as they are slimline and blend into the visor. Clearly this incognito appearance isn’t much use if you hang the wire down from the unit and don’t tuck it away Very Happy Nick
2.2 110 Tipper
Post #325479 22nd Apr 2014 8:44pm
keith
Done my research , bit the bullet and bought this . Itronics ITB 100hd .
Once installed will post report .
Post #326203 26th Apr 2014 11:12am
keith
Fitted with excellent sound and HD video .
Post #333453 25th May 2014 1:41pm
gilarion
I have had two dash cams and both have failed, I then bought a Blackview and though good sometimes it is slow to start, so I bought this one from Amazon. E-Prance Brilliant piece of kit more features than units three times the price Video at 1080 HD and at only £38.29
http://www.amazon.co.uk/gp/product/B00FDQ9...&psc=1
1.Model:AT700
2.Screen:2.7"
3.Processor:Novetek 96650
4.Image Sensor:5M CMOS
5.Lens:6G all glass design,high resolution multi-layer light 148 degree wide angles
6.Video Resolution:1920*1080 30FPS 1280*720 60FPS 848*480 30FPS 640*480 30FPS
7.Video Format:MOV
8.Video Codec:H.264 AVC
9.Image Resolution:2592*1944 2048*1536 1920*1080
10Language:English, French£¬Deutsch,Spanish,Portuguese£¬Italian, Japanese, Russian, Simplified Chinese, Traditional Chinese
11.Card Slot:Tf Card
12.Maximum Card Memory:Up to 32GB (not Including )
Additional Features:
1.Motion Detection:Yes
2.GPS logger:NO
3.G-Sensor:Yes
4.Loop Recorder:Yes
5.Car Plate Stamp:Yes
6.Night Vision:LED
7.HDMI OutPort :Yes
8.AV Out:Yes
9.SOS:Yes
10.Port:1 x USB port, 1 x TF card slot£¬1 x HDMI, 1 x AV OUT
11.Battery Type:Build-in Rechargeable Li-polymer Battery
12.Voltage:DC 5V/1.5A
Brilliant piece of kit and only £38.29
Post #333473 25th May 2014 3:39pm
What puddle?
Buy one that has a screen - many don't. I'm on my FIFTH camera. All the previous four have failed, and the only reason I knew was because the screen went blank. I have bought the Transcend DrivePro 200 now. Seems to be very good, came top in AutoExpress review. Easy to use, which was what I wanted. Now left.
Post #333546 25th May 2014 7:08pm
keith
Same in the back window .
Post #337247 10th Jun 2014 3:04pm
Venomator
Forgive me Keith, but your back window looks identical to the front... Whistle  Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #398790 14th Feb 2015 6:12pm
Page 2 of 4 <1234>
