Home > Puma (Tdci) > Clutch replacement Procedures |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 |
Hi everyone. I am just going to replace my 2009 110 SW puma clutch plate, pressure plate, clutch pump and pivot bearing soon due to excessive rattling. According to puma workshop manual, do i need to use that special plate align tools etc. Also I have heard that coolant pump, clutch sensor should remove etc? (Please correct me if that is wrong). For this reason, should i seek professional LR guarage or would it be alright to get this job done by the normal guarage mechanic. All the costs have to bear by my self since no warranty applies. Please share your thoughts and advice. Thanks a lot.
Kind regards, Diluk |
4th Apr 2014 2:33pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
We have just done the clutch on our mates 110.
We done it on the drive without any special tools, apart from a clutch alinement kit which I have any how, torque wrench & a transmission jack It was a PIG to blead up after though Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
4th Apr 2014 7:23pm |
Hi. Many thanks for the reply guys. Appreciate that! Today I change the clutch kit with slave cylinder. But didn't bother to change the pivot bearing though. First it was impossible to insert the new slave cylinder to the gear box as the metal sleeve was quite big so apparently had to fine it around to fix the problem then it was totally alright. I bought it from UK brand name Borg & Beck but surprised to see the bad fitment. Please have a look the pics of old and new clutch plates below. The two inner small spring were gone and others were shaking badly.
[img]https://www.defender2.net/gallery/albums/userpics/11849/normal_20140408_165738.jpg[/img] Now all ok no rattling no clunks and smooth gear changing. Regards, Diluk |
10th Apr 2014 3:17pm |
