Home > Puma (Tdci) > Oil service warning?
WAFU
England 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Hi guys,
Can anybody advise on whether my oil really needs changing or is it an error based on the following.
2.2 MY 13 with 6000 miles on clock from new, only high speed motorway driving (70-80 ish). Oil service warning came up on dash so researched it on here and found reset procedure which worked a treat, no longer appearing on dash. I would have thought at only 6k miles and used for Mway driving at 5 hours each journey it would not need changing yet? Never even had a DPF re-gen light on yet?
Appreciate any advice on whether you belive my oil needs changing and if the warning will come back on again after a reset procedure has been carried out.
Thanks
Post #320718 1st Apr 2014 7:11am
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Can you please post the link to resetting oil service procedure as I've tried to find it and no luck Embarassed
Cheers It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #320725 1st Apr 2014 7:31am
Happyoldgit
The search facility is often your friend
http://www.defender2.net/forum/topic26474....vice+light
Wink Steve.
http://forums.lr4x4.com
Post #320730 1st Apr 2014 7:48am
sparkylee
Cheers Thumbs Up It's good to be back from the dark side
FFRR 4.2 vogue
Post #320733 1st Apr 2014 7:51am
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Worked a treat for me 2013 Aintree Green 110 Station Wagon SX
Post #320735 1st Apr 2014 8:03am
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
The service interval is 12,000 miles or 12 months; whichever is soonest.
So the 12,000 miles has not arrived, and I am assuming the 12 months is not up yet?
Was your car a factory order or 1 from stock? If the car was a stock car the service light should be calibrated/reset at the pre delivery inspection, this may be when the car arrives at the dealer, not at point of delivery/collection.
Regards
Mark.
Post #320739 1st Apr 2014 8:41am
WAFU
Hi Mark,
The car was in the show room so a stock item and Ive had it for around 6/7 months. I understand what you are saying Thumbs Up
My only other concern was Im sure I read somewhere that the engine somehow based its "oil service" reminder on style of driving/oil quality etc - I guess I got that wrong then Embarassed
Thanks alot Thumbs Up
Post #320779 1st Apr 2014 12:40pm
Mjibex
With the higher speed driving style I would not be worried so much by DPF issues.
For the fact it was a showroom car I would imagine you have the answer - the service light was not reset before delivery - this is fairly common.
The thing to check for on DPF cars is an increase of engine oil; i.e. contamination with diesel. This is not only bad for bearings - but if the level gets too high the engine can go for a little run on its own diesel/oil mixture; this is usually terminal!!
That said I try and change mine every 6,000 miles - I intend to keep it!
Post #321049 2nd Apr 2014 1:20pm
GUM97
The service indicators are set at the factory apparently, sometimes wrongly. Our Disco4 is flashing up 'Service Required' even though it's not even 6 months old yet. An engine to TDi for!
Post #321065 2nd Apr 2014 3:50pm
X4SKP
Hello WAFU
I would get the Service Lights checked at LR, asap, if only for peace of mind.
(especially as this vehicle is around 6 months old).
I had a 300tdi 90 CSW from new and Serviced with LR until 60K, but changed the oil midway between
each 12000 mile Service or each 1/2 year myself, I am convinced it's one of the best service steps
to take. The 300tdi (1994) was actually taken back to LR for a oil change at 1500 miles, this practice
is claimed to be now not necessary, but early ware and oil contamination can be negative factor.
At this point of ownership consider changing the oil, irrespective of the type of driving you are doing. SKIP
Post #321079 2nd Apr 2014 4:41pm
