redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 ![]() ![]() ![]() |
Maybe the Yanks are there to see the Defenders-they don't have them either
Washed and waxed it. Does look much better than the bird sh!t, doesn't it?
![]() ![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I've done absolute nothing in mine today. It's at the garage having 4 x roof spots, a work light and a wheel carrier fitted. Broken door hinge, central locking wire fixed. Rear X member sprayed and an oil leak fixed. Looks like turbo to sump return pipe O ring broken. Photos to follow...
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
looking good! my tdi not quite that clean ![]() my youtube channel |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20590 ![]() ![]() |
Washed and waxed mine too.
^ Lost my defendoor too last week, despite it was attachted to the filler neck with a lanyard! Cheers, Vincent
Either that or pinched but I swear it had come off.
Not sure if I will get another or not now, good product but not going to keep buying over and over just because it flys off. |
Therefore I attached it with a lanyard.... But then, after filling up I forgot to put it back on.
![]() So I can only blame myself for that. ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
what are the benefits of a defendoor? My 109 thread
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Keeps dirt away from filler cap
helps keep damp away from lock helps stops lock freezing in winter add about 100% reduction to the drag coeficient to reduce drag ![]() ![]() |
It keeps the muck out of the filler recess.
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
Locked out of the defender today with keys in the ignition and hours from home. Used another defender key and opened it in under 5 seconds......mixed blessing
![]() Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Took in some views:
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
A key for a different defender? ![]() |
