Home > Maintenance & Modifications > Tow electric socket in the cross-member mounting and wiring? |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
Have any of you mounted the towing electrics in the rear cross-member gap?
Just wondered if you used a bracket or straight to the chassis. Also the ready done plug i bought has a connector ready wired are there any gaps to get it through. Any tips appreciated as will do it tomorrow evening and although im very practical, electrickery isnt my strong point! Defender puma dormobile camper |
26th Mar 2014 8:56pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5772 |
Yep mines in there
Click image to enlarge |
26th Mar 2014 9:20pm |
Lovely job cheers Seb and Andy
only thing is I might have to un-wire the block connector by the sounds of it as it came complete with the wires already so it looks a plug in sort of job, but not sure obviously until tomorrow. Thanks Tom Edit; this is what i bought; http://www.ebay.co.uk/itm/181308267814?ssP...1439.l2649 Defender puma dormobile camper Last edited by SailingTom on 26th Mar 2014 9:23pm. Edited 2 times in total |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 260 |
Sailing Tom, sorry I can't offer any practical support, but would like to join in this thread as it is near enough the same issue I am looking at for my TD5 cross member. Plus how you undo the tow pack wiring loom electrical connector...mounted a receiver hitch months ago, but haven't electrified it yet! Many thanks
Rob |
The plug fits through the hole, it just takes a bit of fiddling.
Andy |
26th Mar 2014 9:22pm |
Top man, thats what I was in doubt over, looking at it quickly I couldnt see how. Much appreciated Defender puma dormobile camper
26th Mar 2014 9:25pm |
I thought the same at first, as mine was mounted on the standard tow bracket, but a bit of fiddling and job done. I just used three stainless steel screws.
Andy. |
26th Mar 2014 9:27pm |
Here you go, Tom:
http://www.defender2.net/forum/topic13747....ing+13+pin This was on a 110 but the principle is exactly the same as for a 90. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
26th Mar 2014 9:56pm |
Fantastic, cheers I searched but didn't find that. Out of interest though yours looks a lot more bits compared to what I bought? Hopefully it will work guess ill just have to try it and see. Defender puma dormobile camper
26th Mar 2014 10:12pm |
Probably because you got the standard 12N and LRA was the 13 pin kit
Andy |
26th Mar 2014 10:46pm |
Yeah, my link was more to illustrate the socket in crossmember arrangement. Darren
27th Mar 2014 7:43am |
Cheers Guys fitted it this morning
Must be easy as took half an hour, Only problem I had is with the 90 puma fuel tank it would go through but wouldn't turn to come out the other side. I Cut the 2 opposite corners as shown in the picture and it slid through a treat. Drilled some holes and gave it all a good coat of waxoyl before fitting it and used stainless screw. All fitted nicely and looks much better/ protected tucked in there. Cheers Tom Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Defender puma dormobile camper |
27th Mar 2014 10:26am |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
I still haven't bothered to do this and I really should hurry up and bother with it too everytime I see the plug I think, I sort that the weekend. And the weekend evaporates!
27th Mar 2014 11:03am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20559 |
Why is that hole I the rear X member? Is it a ruminant from the days of the PTO drives? KEEP CALM AND Drill ON
27th Mar 2014 11:16am |
