Home > Maintenance & Modifications > Tow electric socket in the cross-member mounting and wiring?
SailingTom
Have any of you mounted the towing electrics in the rear cross-member gap?
Just wondered if you used a bracket or straight to the chassis. Also the ready done plug i bought has a connector ready wired are there any gaps to get it through.
Any tips appreciated as will do it tomorrow evening and although im very practical, electrickery isnt my strong point!
Laughing Defender puma dormobile camper
Post #319326 26th Mar 2014 8:56pm
110SEB
Yes the hole goes all the way through so you can feed the cable to the wheel arch to the socket to plug it in. It's behind the plastic shield that protects the back of the lights from mud in the wheel arch.
Just drill holes for the screws in the X member recess. It means your socket is protected and out of the way.
Post #319334 26th Mar 2014 9:11pm
landy andy
Yep mines in there
Post #319342 26th Mar 2014 9:20pm
SailingTom
Lovely job cheers Seb and Andy
only thing is I might have to un-wire the block connector by the sounds of it as it came complete with the wires already so it looks a plug in sort of job, but not sure obviously until tomorrow.
Thanks Tom Thumbs Up
Edit; this is what i bought;
http://www.ebay.co.uk/itm/181308267814?ssP...1439.l2649 Defender puma dormobile camper
Post #319343 26th Mar 2014 9:20pm
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Sailing Tom, sorry I can't offer any practical support, but would like to join in this thread as it is near enough the same issue I am looking at for my TD5 cross member. Plus how you undo the tow pack wiring loom electrical connector...mounted a receiver hitch months ago, but haven't electrified it yet! Many thanks
Rob
Post #319344 26th Mar 2014 9:20pm
landy andy
The plug fits through the hole, it just takes a bit of fiddling.
Andy
Post #319347 26th Mar 2014 9:22pm
SailingTom
Top man, thats what I was in doubt over, looking at it quickly I couldnt see how. Much appreciated Very Happy Defender puma dormobile camper
Post #319349 26th Mar 2014 9:25pm
landy andy
I thought the same at first, as mine was mounted on the standard tow bracket, but a bit of fiddling and job done. I just used three stainless steel screws.
Andy.
Post #319350 26th Mar 2014 9:27pm
Here you go, Tom:
http://www.defender2.net/forum/topic13747....ing+13+pin
This was on a 110 but the principle is exactly the same as for a 90. Darren
Post #319365 26th Mar 2014 9:56pm
SailingTom
Fantastic, cheers I searched but didn't find that. Out of interest though yours looks a lot more bits compared to what I bought? Hopefully it will work guess ill just have to try it and see. Defender puma dormobile camper
Post #319376 26th Mar 2014 10:12pm
landy andy
Probably because you got the standard 12N and LRA was the 13 pin kit Thumbs Up
Andy
Post #319387 26th Mar 2014 10:46pm
Yeah, my link was more to illustrate the socket in crossmember arrangement. Darren
Post #319426 27th Mar 2014 7:43am
SailingTom
Cheers Guys fitted it this morning
Must be easy as took half an hour, Only problem I had is with the 90 puma fuel tank it would go through but wouldn't turn to come out the other side. I Cut the 2 opposite corners as shown in the picture and it slid through a treat. Drilled some holes and gave it all a good coat of waxoyl before fitting it and used stainless screw. All fitted nicely and looks much better/ protected tucked in there.
Cheers Tom Thumbs Up
Post #319462 27th Mar 2014 10:26am
theorangebandit
I still haven't bothered to do this and I really should hurry up and bother with it too everytime I see the plug I think, I sort that the weekend. And the weekend evaporates!
Post #319474 27th Mar 2014 11:03am
Why is that hole I the rear X member? Is it a ruminant from the days of the PTO drives? KEEP CALM AND Drill ON
Post #319478 27th Mar 2014 11:16am
