![]() | Home > Maintenance & Modifications > High performance A/C |
According to his profile, Sandbox has a '97 V8 rather than a Puma, so not really comparable. Having said that, the system should still blow cold air, even if the volume isn't enough to make a dent in the ambient. A leak test and re-gas would probably be a good first step before any major upgrade works.
Beyond that, the comments about insulation are definitely worth considering. Dynamat or similar around the transmission tunnel, seat box and floor will make a real difference to heat transfer from the engine, transmission and exhaust, and something in the roof will reduce the effects of solar gain. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
max peck Member Since: 30 Aug 2012 Location: Dubai Posts: 17 ![]() ![]() ![]() |
Sandbox,
I had the top of the top of the truck wrapped in chrome silver. This helps a lot. you cant see it from the sides just when you look down from above. Also as mentioned by someone previously, there is minimal insulation on the truck and it turns into an oven. I applied dynamat and dynaliner on all of the truck. Helps enormously. Max |
elyassi Member Since: 17 Mar 2013 Location: Abu Dhabi Posts: 17 ![]() ![]() ![]() |
in mid summer i feel the heat in my Defender although its brand new
![]() IMHO you need to check and clean your AC system and insulate you defender. i had similar case with my (1993 Nissan Patrol SWB) in summer although AC system was all new, i found a shop in Dubai using Dynamat insulation products. they fixed 2 layers (Dynamat Xtreme & Dynamat liner) all over the inside of the car, after that i felt the difference and its worth the money actually. |
eddy Member Since: 05 Aug 2012 Location: Mandurah WA Posts: 12 ![]() ![]() |
You would be better off to try one of these replacements [url]http://www.aulro.com/afvb/projects-tutorials/159715-aftermarket-c-td5-110-wagon.html a lot more info on the Good Oil section of the Aulro site.[/url]
