Home > Puma (Tdci) > ok but what happened? (impossible to start)
Zouritte
France 2010 Defender 110 Puma 2.4 SW Java Black
Hi all,
This afternoon i used my Defender to go to the post office and the grocery store (2 starts) and after being park at the Grocery store for about 25min, i came back and haven't been able to start the engine.
I had:
- Red battery light (on)
- no heaters (for ignition) light (the coil-ish symbol)
- the cooling fluid needle topping the hot position (not possible after 5 min drive)
i could hear the engine turning, but (i guess) no fuel injected.... it was definitely an electric problem.
I had to ask a buddy of mine to come and tow me off this parking. But at the moment i came back it the truck to start the towing, it fired up again... looked like a fool but happy it started again.
Would you have any ideas on what could have been the problem ?
Thanks
Tim
Post #318780 24th Mar 2014 7:30pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Mine does this after I fitted an XEng barrel lock that meant the transducer coil had to be moved. Found that when this happened I just exited , locked the defender, unlocked i and then made sure that the fob was close to the lock barrel. Since then only happens one every 3-4 months.
Steve
Post #318806 24th Mar 2014 8:39pm
Maris Widgeon
England 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I have this problem about once a year , when it won't start have to jump out ,lock the doors , unlock again , and it starts without issue. Last time was whilst waiting for the ferry at Caen. Caused a bit of a panic ,and look a bit of a plonker but seems to cure it for another few months.
Post #318808 24th Mar 2014 8:48pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Yep me too .. Happens nearly every time I stop, don't lock and try to restart. I have to lock .. Sit still and wait for the alarm to arm, unlock and then it starts fine. Bit of a pain, but used to it as one if it's charms Very Happy 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #318811 24th Mar 2014 8:56pm
Zouritte
hummm still a bummer, i tried the lock unlock twice, but didn't do anything... i hope i'm done for at least a few months. Sad
Post #318835 24th Mar 2014 9:43pm
Have any of you just pressed unlock before starting?
Try that and see if that cures it, the alarm arms it's self after a short while.
For example if you unlock it get in get out far about for ten minutes and then just hop in and try to start it'll either not start or start and cut out.
If you just press unlock even though it is unlocked it'll disarm the immobiliser straight away. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #318856 24th Mar 2014 10:33pm
Zouritte
I've tried it about 3 times, but at the end, I guess the immobiliser was the problem. But why exactly???...don't know yet Sad
Post #318862 24th Mar 2014 10:50pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Probably a million miles away with this but just to throw another idea in the mix...
If the immobiliser was kicking in as you guys suspect, wouldn't the engine immobilised tell tale light come on ?? (red engine symbol with what looks like a lightening bolt flash through it)...
I only ask this as (and mines a Td5 but assume similar logic applies), I had a similar issue to what you describe and it turned out to be one of the relays under the drivers seat had worked itself a little loose and was making intermittent contact. I bent the contacts on the relays and then cable tied them in, in an attempt to achieve a better contact and since then, no issues.
Worth a look perhaps, if nothing else for process of elimination.....
(I also seem to recall it being suggested once before that a bad earth on the ECU could cause similar problems and folks got around it by running a new earth from ECU casing back the battery..... don't quote me on that though) Jon - 110 td5 [sold]. Currently Defenderless.
Post #318899 25th Mar 2014 7:08am
Porny
Site Sponsor
It can be an earth fault - or a fault in the ECU which happens especially on 2007 and 2008 Defenders - and the fix is a new ECU. Especially as the temp gauge goes high. There is a number on the ECU which will show if in the effected range.
If it does it again, disconnect the vehicle battery, wait appox. 1 minute and reconnect. If this fixes the problem, the fault codes read and see what is stored.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #318943 25th Mar 2014 10:52am
It would indeed, I just didn't mention it because it might not be noticed especially to a driver that's new to the Defender quirks perhaps. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #318962 25th Mar 2014 12:27pm
dgardel
Italy
Check the main relay and socket under the driver (for you) seats Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #318998 25th Mar 2014 2:42pm
munch90
can happen if you turn ign on then instantly to start , units not fired up completely and talking to each other properly .
normally turn off leave it a minute ,turn on ign wait few seconds then turn to start
Post #319046 25th Mar 2014 7:03pm
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
My money would be on this one, I had similar situation with the engine cutting out as the temp needle shot up. Re-seated all the under seat relays and never had an issue since.
Post #319070 25th Mar 2014 8:07pm
Zouritte
This relay stuff could be a good path to the solution, i've been playing around in this electrical box lately, i'll take an eye on it, and if it happens again i'll try the battery disconnection and reconnect after a minute or so... I'll keep you posted if i find something.
Thanks
T.
Post #319130 25th Mar 2014 9:47pm
spudfan
Ireland
If you put the key in the ignition and turn it and the immobiliser light stays RED and lit up the vehicle will not start. This happens with a spare set of keys I got programmed by a dealer. But if the LOCK/UNLOCK is carried out with the fob the immobiliser light goes out when the key is turned and the vehicle starts. This points to a glitch in the programming of my spare keys to me. But if your vehicle does not start with the LOCK/UNLOCK on the fob then it points to an immobiliser problem as others have said but how you check/remedy this I do not know. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #319161 25th Mar 2014 10:33pm
