Home > Maintenance & Modifications > High performance A/C
Sandbox
United Arab Emirates 1997 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Does anyone know of any high quality/performance A/C kits for the 90/110?
I have been shocked how bad the A/C is on defenders, it's not a luxury but a necessity in the UAE.
Post #318600 24th Mar 2014 7:07am
K9F
We obviously don't experience the temperatures you do but the airconditioning on my Puma is great. Older Defenders heating/airconditioning systems were notoriously irksome especially on heat. I do not know of anyone that has fitted an aftermarket one just OEM ones but you are probably best placed to find a local airconditioning servicing/fitting dealer to find out what can be done for you. I did look at a Discovery Japanese import a few years ago that had an autonamous air conditioning unit for the passengers in the rear, that may be the best and easiest route for you perhaps?. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #318601 24th Mar 2014 7:12am
Sandbox
Post #318613 24th Mar 2014 8:07am
K9F
It does perhaps look like a viable option. You may have considered the fact that you will also need an engine mounted compressor and a condensing radiator. There are a few threads on fitting aftermarket aircon I'll have a mooch and see what I can find.
http://www.defender2.net/forum/topic13934.html?highlight=aircon
Maybe worth contacting 110 from this thread as it appears he has had experience....
http://www.defender2.net/forum/topic8718.html?highlight=aircon
Somebody else considered a conversion here:
http://www.defender2.net/forum/topic7198.html?highlight=aircon If you go through life with your head in the sand....all people will see is an ar5e!!
Post #318634 24th Mar 2014 9:25am
K9F
Possible solution.....Is a standalone unit....
Try here, they have an agent in the UAE too..... Thumbs Up
http://www.rdac.com/products/off-the-shelf-hvac If you go through life with your head in the sand....all people will see is an ar5e!!
Post #318644 24th Mar 2014 10:23am
Sandbox
As luck would have it they've a distributor in Dubai!
I've just sent them an email, we'll see what they come back with.
Post #318653 24th Mar 2014 11:18am
K9F
Good news.... Thumbs Up Hopefully the inside of your truck will be as cool as polar bear poo in no time at all! Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #318658 24th Mar 2014 11:37am
munch90
you can get a ac enhancer that you add to the gas
never tried one .but thought worth a mention
Post #318661 24th Mar 2014 11:49am
Sandbox
Out here it'll probably still be like luke warm gorilla Censored during the summer... but we shall see.
Post #318664 24th Mar 2014 12:01pm
K9F
Sandbox,
Some more good information about the linked ones I sent you here:
http://forums.lr4x4.com/index.php?showtopic=68395 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #318666 24th Mar 2014 12:08pm
Sandbox
This looks pretty smart: http://www.rdac.com/sites/default/files/ca...liners.pdf
So am I right in thinking I wouldn't need a air-con pump on the engine?
I wonder if this would fit under a roof rack http://www.rdac.com/sites/default/files/catalog/Ecat/Rooftops.pdf
Post #318687 24th Mar 2014 1:25pm
Sandbox
I Just called the supplier and both would need a compressor on the engine.
Post #318696 24th Mar 2014 1:46pm
Cheshire110
+1 for the standard (if looked after I guess) i often get condensation on the outside of the screen if I put the AC on upwards rather than at me because it comes out so cold! Cheers, David
Post #318747 24th Mar 2014 5:58pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
the problem may not be the AC but the poor thermal insulation of your/our Defenders...
Two years ago I was coming back to Portugal from UK, crossing Spain in mid August, 45º C outside...inside my 110 it was a lot cooler, maybe 27º/28º, but I was still sweating!
However with the AC and fan on max, with the cold that the AC was debiting it should have been a lot cooler inside.
I noticed that the gearbox tunnel, floor and seat box were hot as hell.... And I believe that that was the main reason why the Defender wasn't cooler inside.
Instead of spending a lot of money on a new AC system, I would opt first for geting a much better insulation on my vehicle... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #318868 24th Mar 2014 11:27pm
Sandbox
The aircon blows warm in the UAE summer, you can't compare.
There is a saying here, if it's over 40 leave the defender at home.
Post #318895 25th Mar 2014 6:35am
