Home > Maintenance & Modifications > Stainless steel EGR blanking kits
Page 2 of 16 <123 ... 141516>
Robofarmer
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
fekete wrote:
Enjoy your night shift bud....I've just sank another full brekkie Rolling with laughter just had the choice of T Bone or Brekkie guess what full Brekkie every time...and i'm still eyeing up the contents of the fridge...back to work tomoz so i will work it of Whistle
Top man fekete full breakfast for me everytime too !!!! Thumbs Up Thumbs Up 2008 110 County utility
ex 1988 defender 90 ,td
ex 1970 series III
Post #31454 4th May 2010 9:14pm
K9F
Feedback!
Well had the 18mm blank on for nearly a week now. No MIL light and may be my imagination but appears to be marginally more economical (will see with next fill). What isn't imagination is how much quieter the engine is! Will wait till I get my remap back on and go a size smaller. Shouldn't be too difficult now the studs have been removed and replaced with the ss bolts 10-15mins I reckon.
Hands are healing nicely having ripped 'em to shreds trying to clear the studs to get the blanking plate on last week instead of just removing them!
Happy days! Thumbs Up Summer's knocking on the door! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #31690 7th May 2010 2:20pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Ill put mine on Sunday should be an easy job for me with having the bolts there already Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #31691 7th May 2010 3:24pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Re: Feedback!
Completely understand about the scars, mine are healing now Wink It was alot easier on a county model without the air con pipr 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone
1982 Series III SWB Hardtop - gone
1997 300Tdi Defender 90 Hardtop - gone
1983 Series III SWB Station Wagon - gone
1979 Series III SWB Station Wagon - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1959 Series II Truck Cab
1984 Series III CSW
2004 TD5 90 CSW
Post #31766 8th May 2010 8:21pm
MK
Suggestions?
doesn`t look very promising for my knuckels. Should I remove the expansion tank to start?
cheers
M Puma 110" SW
Post #31768 8th May 2010 8:58pm
K9F
MK,
No need! Just buy a bottle of antifreeze and disconnect the pipe at the bottom of the expansion tank it will give you enough room! If you've got some gloves put 'em on! There's lots of sharp edges and it'll save a week of healing! If you've got studs remove them rather than try to get clearance to fit the blank and replace with the bolts! Took me a while and a couple of calls to Robofarmer to get it done but it shouldn't really take more than 30-40 mins first time! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #31770 8th May 2010 9:28pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
K9F wrote:
MK,
K9F - if you're changing your plate, maybe you could take some photos of the job Very Happy Picture; thousand words... and all that Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #31771 8th May 2010 11:39pm
MK
From AndrewS` pics I can see original bolts still there Shocked Why RoboF supplies new bolts? Sorry for the stupid question Puma 110" SW
Post #31774 8th May 2010 11:53pm
K9F
Alantd,
Job took longer than expected and I had to get vehicle back together to get back to work. Unfortunately all was a bit of a panic and I didn't take pictures. Got 2nd service in 2,500 miles so will have to swap back, will take pictures then if someone hasn't beaten me to it.
Dog Thumbs Up Dog
MK,
On Andrews's photos they are the original studs (not bolts) he has just removed the nuts off them to facilitate removal....
Some vehicles have studs fitted where you just remove nuts to undo, others have bolts that you just extract.
The difficulty of the task depends on whether you have bolts or studs as original fit
If you have studs fitted you have to make sufficient room to pull the EGR Valve assembly clear of the manifold to fit the blanking plate. I couldn't manage this as I have aircon and could not obtain sufficient clearance with all the pipes etc.
Quick call to Robofarmer and he said "Use a star type socket and remove the studs completely and replace with the bolts I supplied!" Makes the job and any subsequent blanking plate fit/removal much easier. Hope this makes sense.
If you've got bolts as standard just whip 'em out retain the gasket and replace with a blank. Job jobbed!
Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #31778 9th May 2010 8:04am
dgardel
Italy
it's sufficient a little modify....
off course the photos is only the idea, normally we make this kind of solution on Gas & oil plant blank/cut-off plates
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31806 9th May 2010 8:03pm
Robofarmer
MK wrote:
Suggestions?
cheers
M
Mk def no need to take the expansion tank off just try and do the job with engine cold to start with would be best!. If you do end up change,n a plate after a run just wait a reasonable amount of time for engine and water temp to cool a little and then release the expansion tank top slowly for a min then tighten again and then squeeze clip and remove black water pipe out of your way. and you should,nt lose more than a cupfull of coolant .
Thumbs Up can,t help you with the sore knuckle proplem though. Laughing Laughing 2008 110 County utility
ex 1970 series III
Post #31812 9th May 2010 8:34pm
alantd
K9F wrote:
Alantd,
Dog Thumbs Up Dog
I know those jobs Very Happy It's usually preceded by my suggestion to my wife that "it'll only take me 10 mins". 2 hours later she comes out to see what the hell has happened, to find me red faced, sweating and cursing as I try to at least get back to the point where I've not broken it.
I need a mechanic's "undo" button. Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #31860 10th May 2010 12:15pm
MK
Laughing Laughing Laughing Therefore I didn`t try during the WE Puma 110" SW
Post #31863 10th May 2010 12:23pm
K9F
Alantd,
Your post is creepy!!!! You were watching me and listening in weren't you? Wonder how many others use the "It'll only take me 10 minutes, honestly!" and the accompanying "It's all gone horribly wrong!"
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #31864 10th May 2010 12:23pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
how are people geting on with this iv just ordered mine
what is the best size to start with ?
and any one got any real good storys of what the performance has beeen like after fitting
cheers steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #32052 12th May 2010 12:11pm
