Home > Puma (Tdci) > off we go......no we don't
Page 3 of 4 <1234>
Caterham
Blackwolf will get photo of fuel over in a bit but in the meantime what should I be looking for in terms of resistance on the clutch switch?
Post #318104 22nd Mar 2014 12:40pm
Caterham
Fuel from other day....
Post #318196 22nd Mar 2014 8:03pm
If you rub the crud between finger and thumb does it feel gritty or slimey? It looks very like the dreaded "diesel bug" from the photo (the slimey option).
If so you will need to empty the tank, remove it from the vehicle, take the pick-up assembly out, and clean all traces of crud out of the tank, pick-up, and breather pipe (which is probably where most will be). Then flush the lines to the filter head with clean fuel, and put the whole lot back together. Be prepared also to fit another new VCV since it is almost always required.
Post #318228 22nd Mar 2014 9:45pm
Caterham
Just put me finger in the tub and was going to say it was grit but then noticed it easily changed to what seemed more like powder?
Post #318235 22nd Mar 2014 10:06pm
RustyM
England 2016 Defender 110 Puma 2.2 XS CSW Corris Grey
Try Soltron fuel treatment in the tank. 90 & Wolf
110 XS
Previously owned SI SII SIIa SIII & Light weight (air portable)
Post #318251 22nd Mar 2014 11:54pm
Caterham
Thanks rustyM
Blackwolf - had you known from the outset you would have to replace the vcv do you think fuel treatment would have been sufficient?
Anyone know if Halford sell tdci fuel filters?
Post #318283 23rd Mar 2014 8:47am
RustyM
You can do some basic home testing on a vcv before replacement Exclamation This maybe of some help.....
Yes in all "diesel bug" cases in the marine world I have come across only filter change required during the first stage of treatment.
M 90 & Wolf
110 XS
Post #318290 23rd Mar 2014 9:07am
Caterham
RustyM
Does anywhere sell this stuff 'off the shelf '?
And thanks for the information.
Post #318295 23rd Mar 2014 9:20am
No, I didn't. I drained the tank, changed the filter (several times), which made no difference. I then dropped the tank, cleaned a lot of crud out of the breather, pick-up, and tank itself, flushed the lines, replaced the filter, and it still didn't run! Even though I was sure the tank was clean, I had the fuel "polished" and changed the filter again. Still not right.
(Symptoms rough running, rough idle, stalling on tick-over, lack of power accelerating).
Almost in desperation I eventually spoke to the senior tech at my favourite main dealer. He immediately diagnosed either EGR or VCV, but said the lack of any stored fault codes ruled out the EGR (he also didn't know it's disabled through software). He also stated that on every single vehicle they've had through the workshop for the water-in-fuel-reroute-breather TSB they've had to replace the VCV to get it running right afterwards.
I bought my VCV from Ford since the LR dealer had none in stock, and the Ford parts man said "we sell hundreds of these". He knew the part number from memory.
So no, I didn't know at the outset, but would now change it as a matter of routine. It is clearly a sensitive item and easily damaged by contaminants of any kind.
Post #318296 23rd Mar 2014 9:21am
RustyM
I see you are up in Birmingham so I am not sure who is a supplier? I would suggest online from here maybe your best option.
http://www.asap-supplies.com/green/aquasoc...yme-314101
As I have not had any dealings with small engines that have vcv's Blackwolf's advice is what I would also act on with regards to the vcv Thumbs Up
M 90 & Wolf
110 XS
Post #318301 23rd Mar 2014 9:35am
Caterham
Thanks BW.
I recall your previous posts.
The thing I find most strange and I believe we've both experienced this is the short lived improvement from replacing the fuel filter.... if the vcv was shot (and clearly it was) why would new filter make an improvement?
Post #318302 23rd Mar 2014 9:36am
Caterham
RustyM. I have replaced one vcv already and as such loathed to replace another without some reassurance it's going to solve problem?
Post #318310 23rd Mar 2014 9:51am
RustyM
If it was me I would go for the fuel treatment and filters option Thumbs Up 90 & Wolf
110 XS
Post #318312 23rd Mar 2014 9:55am
mk1collector
Are you sure all that muck didn't come off the rim of the filter when you emptied it? Muck can still sit on the rim of the filter from driving.
Post #318340 23rd Mar 2014 11:31am
Caterham
That was from the drain at the bottom but I guess you're right in so much as it could have been from the drain point?
Will drain some more and so what’s what....i might put some rape over the drain for future reference......good idea.
Post #318343 23rd Mar 2014 11:35am
Page 3 of 4 <1234>
