Home > Maintenance & Modifications > OEM NAS step bumper 240Nm
Matthew_Mills
So I've just picked up my OEM step bumper and reading the instructions most bolts are rated at 45 or 58Nm but the 2 next bolts that secure the bumper to the rear face of the cross member are stated as being 240Nm... Seems massive compared to all the others!
Opinions please... Seems massive and in fact higher than my wrench goes!
Help appreciated...
Matt
Post #317993 21st Mar 2014 11:08pm
Is that the two range bolts? Around m16 or there abouts? KEEP CALM AND Drill ON
Post #317997 21st Mar 2014 11:15pm
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
As tight as possible is best, or 3 white knuckles if you want to be precise.
Post #317998 21st Mar 2014 11:16pm
Matthew_Mills
Exactly the 2 hex M16s...
I've also just seen the 2 spacer for the vert ends the instruction just show a '?' So I assume that means use the if? What there's a gap? Daft instructions why don't they just use words...
Post #317999 21st Mar 2014 11:18pm
They are that tight because they are two of the main load bearing bolts. I removed my whole step a week or two ago.
Didn't use any torque settings.
Those two m16's I'd tighten as much as possible (with in sensible reason)
The bolts nearer the extremities need to be tight too but don't over do it or it will buckle the X member.
Basically the bigger the bolt the tighter it should be because it's load bearing.
I'd copper grease them too for easier removal in the future.
In all honesty I wouldn't bother with the torque settings and use your own judgement. KEEP CALM AND Drill ON
Post #318003 21st Mar 2014 11:34pm
If you want any photos of mine I'd happily take some and PM you them so you can see what us what and where. KEEP CALM AND Drill ON
Post #318004 21st Mar 2014 11:36pm
Matthew_Mills
All of the other are typically 45Nm which seems low but 240Nm for just these 2 feels like a mis print!
Post #318006 21st Mar 2014 11:41pm
LR90XS2011
if you check the internet there are loads of standard torque charts which may help DEFENDER 90 TDCI XS,
Post #318020 22nd Mar 2014 6:31am
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Matt, I fitted one to my Puma a few weeks ago, yes 240nm is correct for two centre bolts to rear cross member (they're taking all the strain). My torque wrench only went up to 220nm, so I did it to that, then a bit more for luck - can't see them ever coming loose!! Oh, yes and as mentioned, I put copper grease on all bolts during install
Pic below...
 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #318028 22nd Mar 2014 7:19am
Matthew_Mills
Okay, so I guess the instruction leaflet is so old anything incorrect would have been addressed by now... And as suggested above I'll be using copper grease... Pics to follow...
Post #318081 22nd Mar 2014 11:20am
Matthew_Mills
Before
After
Job done...
We'll not quite, kit should have had 2 M16 x 30s but one of mine was a 25! Fitted but of to the dealer Monday for a replacement.
Typical!
Post #318144 22nd Mar 2014 5:11pm
Thumbs Up You might find the tow hitch is a little high in that location if you tow.
I know it sits a little low but I reckon in it's current position it will be too high. KEEP CALM AND Drill ON
Post #318157 22nd Mar 2014 5:39pm
Matthew_Mills
I doubt it will ever get used to tow anything... Purely positioned for recovery use... Frankly even in the lower position it's higher than standard height!
Post #318158 22nd Mar 2014 5:46pm
Ah, not a problem then. Thumbs Up I got my ball and pin hitch for that same reason too. I've used it once too and pulled out a 2 ton van out of mud no trouble. KEEP CALM AND Drill ON
Post #318165 22nd Mar 2014 6:12pm
Matthew_Mills
Yep... There's a Zeon 12 up front. So as well as the odd pull the pin is so I can 'anchor' from the rear for the odd heavier pull... Not a 100% about using the step bumper as the bars that direct the load to the chassis main members have elongated holes to allow for adjustment. With the amount of fixing I'm sure it will take a reasonable load.
It won't get any abrupt 'tugs' because I have a kinetic recovery rope... Steady load always better Thumbs Up
And more importantly I won't be digging any more holes in Mother Nature, grounded the old one 3 times last weekend. I kind of knew I'd made a mistake when I bought it, and lifting the whole drop plate 1 hole was not enough...
Anyway will be putting it up for sale soon... The old tow set up!
Cheers for all the help and advice peeps. Bow down
Since had a good wash! All clean for the next outing Rolling with laughter
Post #318182 22nd Mar 2014 7:24pm
