Home > Puma (Tdci) > Vibration / Rattle
schuee
Vibration / Rattle
Lately I have noticed a vibration in the drive train mainly when changing through the gears, all I can describe it like is when you accidently change into too high a gear say changing into 5th gear when you meant to change into 3rd and then the revs are not high enough and you experience a vibration until your up to speed.
So this morning I put the transfer box into neutral and changed through the gears, reverse 1st, 2nd and 3rd no vibration at all, then when in 4th vibration starts a little until when in 6th there is a right clatter and vibration from below just under the cubby box area, I will have a look underneath later, though before that just wondering if the good people on DEF2 had any thoughts.
Keith
Post #318082 22nd Mar 2014 12:24pm
check your propshafts and UJ's
have you modified the suspension ?
Post #318173 22nd Mar 2014 8:03pm
Are you sure it's not the Gearstick rattle issue? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #318179 22nd Mar 2014 8:15pm
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
When you ran it up with the transfer box in neutral did it vibrate in 5th gear, as this is direct drive on the MT82, if it did you can rule out the gearbox. It would be worth getting someone to drive the car up in neutral and feel both front and rear propshafts to see if they are vibrating, also check if it does it in low range.
Post #318205 22nd Mar 2014 9:26pm
schuee
Thanks for the advice all, I will check the propshafts and UJ's though nothing modified on the suspension, also not heard anything before regarding gearstick rattle ?
When transfer box in neutral and in fifth gear it does rattle, what I did notice is that by dipping the clutch it stopped and letting it back out the rattle / vibration returned, also forgot last week that in low box 1st gear drive was erratic with rattle noise, though tried it this morning and it seemed OK, well it is a Defender Laughing
I had the clutch replaced around 20,000 because of the rattling springs, which cured that and also I did have it in for the transmission brake binding a few times, which was sorted though since then I need to apply handbrake with more clicks than I would expect to hold vehicle.
Keith
Post #318329 23rd Mar 2014 11:58am
schuee
Well I took the 110 to the dealer during the week, and they accompanied me on a road test, could possibly be another clutch replacement on the books. It had a new clutch in around 20,000 miles which sorted out the clanging rattle whilst idling. The technician said there would have been uprated clutch's available since then, I did mention to him about the heavy duty clutch, though he did say that it would make the clutch pedal heavy to use
Also booked in for injector pilot learning, rear half shaft's replacement, rear diff pinion oil seal renewal due to a leak, and new side runner due to paint flaking off.
Getting all this done before the warranty expires, must say my dealer have been excellent regarding any issue's and getting warranty work carried out Thumbs Up
Out of curiosity has anyone had the heavy duty clutch fitted, and what would be the benefits?
Keith
Post #321797 5th Apr 2014 9:11pm
MK
As far as I know there no such thing like a HD clutch for the Puma. I understand Porny is working on some of this HD clutch idea. Puma 110" SW
Post #321812 5th Apr 2014 10:46pm
