Home > Maintenance & Modifications > Door Seals |
gprich Member Since: 14 Jun 2013 Location: East Devon Posts: 42 |
Martin,
Any chance of a couple of photos? |
21st Mar 2014 11:06am |
Just a reminder, water can also get in between the windscreen rubber and the frame. It often seeps in at the top of the rubber(the roof design sometimes makes this permanently wet depending on melting snow/orientation etc) then tracks down the sides inside the rubber seal to empty at the bottom. This is obviously just above the bulkhead seal inside and you can check by leaving rolled up kitchen roll to see if it gets wet
p.s. Last year, LR did in fact pop up the roof, change the foam seal, re-finish the inside of the frame (it was all corroding) and fit a new rubber seal and screen (heatinf now works) together with my own new stainless "hinges" - they even coated them blue...no more leaks so far Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
21st Mar 2014 3:04pm |
ZE see here, it is a German company http://www.yachticon.de/Repair/Sealing-and-Glueing:::82_84.html Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
21st Mar 2014 6:47pm |
