Home > Wheels & Tyres > Sidewall and handling
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I'm looking at doing some suspension mods to improve the on road handling and to cut down on body roll etc, question is, do tyres play a big part in handling too?
My 265/75/16 Duratrac's are great but I've heard they have a fairly soft sidewall, does that mean they'll flex when cornering more? If so, is it worth swapping tyres before doing anything else?
Cheers in advance.
Post #317903 21st Mar 2014 8:01pm
mk1collector
Yes. Lower profile means less roll
Post #317907 21st Mar 2014 8:08pm
Lambley
I was thinking about the actual thickness and sidewall strength rather than the depth, some tyres (BFG's) have a strong sidewall, so does that make them handle/corner better or does it make no difference?
Post #317913 21st Mar 2014 8:15pm
The BFG's certainly are stronger sidewalls but handling doesn't really make much difference as they aren't the type of tyres to go mad on.
The are an improvement though yes imo WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #317914 21st Mar 2014 8:18pm
If you're going to be that serious about improving the handling, then you need to swap to 18 inch wheels (or 20's but they can make the ride very harsh) with much lower profile tyres. However, if you do the suspension mods that you've talked about elsewhere then I think you'll be pleasantly surprised and probably won't feel the need to mess about with wheels. Darren
Post #317974 21st Mar 2014 11:00pm
Lambley
Cheers Anorak, I've bought a rear ARB today and I'm looking at probably Koni shocks and a Superpro bush kit, but wondered if the actual tyre mattered much, some have stiffer side walls than others, if not then i'll leave them as they are, after reading a few reports of Goodyear Duratrac's they are supposed to have a softer sidewall and are lighter, I don't suppose it'll make that much overall difference to body roll but I didn't want it to cancel out the suspension upgrades
Post #317980 21st Mar 2014 11:25pm
barbel jim
Sidewalls will make a difference Paul, but you'll slide about long before that. A softer compound rubber would make a bigger difference IMO
Post #318063 22nd Mar 2014 11:00am
