Home > Puma (Tdci) > Embarassing how do you drain PETROL out of Puma DIESEL tank?
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Self-explanatory title, it seems I was pre-occupied thinking about something and filled my tank with unleaded instead of diesel. Anyone know how to drain it out? Help plase!
Amazingly the Defender still runs but it's not at all happy about being fed petrol! Embarassed Embarassed Embarassed 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #317862 21st Mar 2014 5:12pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
ou take the spout of the tank and suck it out !
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #317864 21st Mar 2014 5:14pm
TD5 SMUT
United Kingdom 2005 Defender 110 Td5 XS DCPU Java Black
Hi
can you take the fuel pipe off under the bonnet by the inlet somewhere and run it all into a tub (extended hose etc) and leave the ignition on??
Post #317865 21st Mar 2014 5:15pm
Natlas
Tried siphoning but don't seem to be able to keep the hose in the fuel, going to try another hose. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #317869 21st Mar 2014 5:20pm
Disconnect the fuel line inlet side nearest the fuel filter, that way you won't be running it through the filter either as it will come direct from tank. Might pay to park on a slight angle too to help the gravity flow.
(Be careful) $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #317873 21st Mar 2014 5:26pm
landybehr
if you noticed that mistake while still being at the fuelling station you could ask them for help.
Possibly they are prepared and have pumps at hand.
Good thing then is you haven´t started the fuel pump by that time and pure Diesel is still in the fuel filter and the lines. When all is pumped out and Diesel filled in again - no chance for damage.
Post #317879 21st Mar 2014 5:36pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Lidls were doing a special offer on transfer pumps last week. Don't know if it's still on.
Post #317880 21st Mar 2014 5:39pm
Natlas
No such luck landybehr, it has been driven for a couple of miles!
Also have found the fuel filter by the back wheel but no obvious way of disconnecting the pipes. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #317881 21st Mar 2014 5:40pm
Natlas
Luke - A lidl transfer pump, what's that intended for originally? 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #317883 21st Mar 2014 5:41pm
redhandluke
Oil transfer pump intended to pump fuel. At Lidl supermarkets. Hope this helps.
Post #317885 21st Mar 2014 5:46pm
Natlas
It looks to me like there is a low pressure connection to the fuel filter that can be released by pushing in the small blue bit of plastic, can anyone confirm that?
Now off to look in my Dgardel manual for clues to above.
Confused 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #317886 21st Mar 2014 5:46pm
Natlas
OK Luke thanks, I may well go and look, pity its 10 miles away! 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #317887 21st Mar 2014 5:48pm
Natlas
Anyone know if I can just undo the water drain from the fuel filter and collect all the petrol that way? 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #317893 21st Mar 2014 6:16pm
K9F
Older Defenders used to have a drain plug in the tank. Pumas apparently do not. Below is a direct cut and paste from the workshop manual....
Fuel System - General Information - Fuel Tank Draining
General Procedures
1. Remove battery cover.
2. Disconnect both leads from battery, earth lead first.
WARNING: Fuel vapour is highly flammable and in contained spaces is also explosive and toxic. Always have a fire
extinguisher containing FOAM, CO2, GAS OR POWDER close at hand when handling or draining fuel.
3. Using a fuel recovery appliance, drain the fuel from the tank
into a sealed container. Follow the manufacturers instructions
for the connection and safe use of the appliance.
4. Remove filler cap and insert hose into filler neck.
5. Connect bowser earth line. Drain fuel.
6. Connect battery leads.
7. Fit battery cover. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #317896 21st Mar 2014 6:29pm
Well just to scare you all to maintain the vehicle warranty on a Mini one after a misfuel the main dealer price is 6800 inc Rolling with laughter so if your in a three year old one it's near a CAT D Shocked
Post #317902 21st Mar 2014 7:00pm
