Home > Puma (Tdci) > low range first gear
spudfan
Ireland
Was in low range first gear in the Puma yesterday. Got passed out by two snails. Boy those boys with the shells sure can move. Very Happy 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #31727 8th May 2010 2:25pm
Grockle
Re: low range first gear
where were ya Spud Upper O'Connel St Laughing 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #31728 8th May 2010 2:44pm
Dont ya just love the anti stall Mr. Green
Post #31739 8th May 2010 3:54pm
dgardel
Italy
First gear low range, try to push the brake w/o touch the throttle............... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31746 8th May 2010 5:23pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Was using it to its full effect yesterday down a very rutted farm track, no matter what obsticle it came accross the revs stayed still and it just clambered over everything. Was quiite relaxing really...
Untill I stopped at the main road for a bit, forgot it was in low box and tried to set off onto a main road in low first... Duh.
One thing that got me thinking though, what would happen IF you had it in low first, put the handbrake on and lifted the clutch? Would it start ripping the ground up or rip the transmission to bits?
Post #31755 8th May 2010 5:57pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Depends on whether you'd locked the centre diff. If you hadn't, it'd just drag the back wheels (the handbrake is on the rear propshaft. Lock that up and it'll put all the power to the front wheels.
If you had locked it. you'd probably just destroy the handbrake.
Antistall is only doing a fairly determined version of what you might try setting off. I can drive through the handbrake in high ratio if I put my mind to it so low wouldn't be too much issue for it Smile One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #31772 8th May 2010 11:46pm
warren
Ahh! Cheers for that!
Was one of them things that was running through my head, but would have probably been expensive to put right if I ever daft enough to actually try...
Post #31776 9th May 2010 12:12am
Setok
Finland
Embarrassingly I got to try that at a short LRE thing a while back. I'm not used to using the handbrake in my Caterham (as in the old ones it's in an awkward place), and just park in gear. I had been doing a few minutes of the practise course, marvelling at how well it copes just with the anti-stall, when the instructor points out I've got the handbrake on Shocked Embarassed
Post #31786 9th May 2010 10:53am
