Home > Puma (Tdci) > wont even break when its supposed to?
Page 4 of 5 <12345>
K9F
Experience probably....The best tool in the box! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #316659 17th Mar 2014 5:48pm
Caterham
Couldn't agree more
Very Happy
Post #316660 17th Mar 2014 5:52pm
Lorryman100
adafish wrote:
Lorryman100 wrote:
Caterham, I will be down in Wythall for a week beginning the 21st of April (going to see Dave to get Landyglass fitted.), and if you are still having issues then, you could always pop around to where we are staying and I will plug some tools in and have a little look see if you wish? Thumbs Up
...............what tools you got that different to what he's already tried ?
The same tools as the dealer probably (SDD and IDS legacy) plus a MSV2 (prefer the live data screen) also if the fault can be narrowed down I can plug in my Pico scope and base the readings received on the multitude of readings/values I have saved from known working components. Thumbs Up
Post #316667 17th Mar 2014 6:11pm
Caterham
Beginning to think the only tool round here is me Embarassed
Post #316672 17th Mar 2014 6:23pm
Caterham wrote:
I've become so suspicious of my def with all the problems I'm actually wondering now if there's anyway I've ended up with one of the early engines like what Spudfan had ie the ones with the dodgey oil jets
Not a chance on a 2011, unless someone found a 4 year old engine lying around the factory!
Post #316687 17th Mar 2014 7:20pm
munch90
custom90steve wrote:
munch90 wrote:
sorry but never know a egr to cause noises , just smoke , power issues
with all the money you have throw at it and hassle , why not get it mapped and egr off
They can do, but not knocking. Faulty EGR sometimes does chatter and cause a scraping sound but;
A. It's occasional not constant so occurs at irregular intervals although every few minutes not once in a blue moon.
B not very loud at all except for if your specifically listening for it.
if you got a noise from the egr valve yes but then its knackered .im talking causing engine noise
Post #316688 17th Mar 2014 7:23pm
Caterham
The egr......I suspect is ok. while stationery if I rev the engine to about 2k I believe I can hear the egr open then close and I get chukka chukka when I turn the engine off
The knocking I refer to is occasional and as I've always thought sounds like the knocking I'd expect to hear from wrong fueling.....
Def went in for replacement breather on fuel tank which apparently ended with tank removal....car ran a treat for a day or so after....overtaking cars and all sorts which for anyone who knows me means something was out of the ordinary (ordinarily good in this instance)
When I did service / fuel filter..again immediate improvement but short lived.
Mostly happens first thing in the morning but has happened a few other times..can pull off and seems like the engine takes a few seconds to catch up.....bit like the clutch is a great big rubber band and it's unwinding???
But the annoying part is the knocking.........sometimes low revs in top gear and no hesitation, just smooth like you'd expect from a modern diesel...........other times in what 'I' would expect to be as close as to make no difference the same circumstances and the fueling seems to be all wrong????
I've wasted plenty of money already so it may come as no surprise I'm considering 'wasting more '.....
How much to replace the engine loom?
Whistle
Post #316698 17th Mar 2014 7:42pm
LR90XS2011
I will be massively interested to know if Lorryman can sort this out for Caterham, try imagining how frustrating it would be owning his Land Rover DEFENDER 90 TDCI XS,
Post #316720 17th Mar 2014 8:07pm
Caterham
Blackwolf....i'm sure u r iright ...not a chance but with my paranoia I suspect perhaps has been rotting in a field for a long time just waiting for some mug with big ears to turn up ....
Frustrating is nothing compared to the pyschoatric costs.
Post #316734 17th Mar 2014 8:17pm
Did you change the VCV? The symptoms sound lot like a faulty VCV. Perhaps you've found another faulty one.
Post #316740 17th Mar 2014 8:22pm
Caterham
sorry thought I'd replied to this already....
yes replaced the vcv......can't recall now whether it made any difference or not......seem to think it didn't (just made my wallet thinner)
Laughing
Post #316816 17th Mar 2014 10:12pm
Caterham
Embarassed
Embarassed
just had a call from the body shop to confirm def paint work is ready.............
and they've taken it to service as the engine malfunction light is on. Whistle
Embarassed
Post #317159 19th Mar 2014 12:27pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
I hope you removed the blanking plate Big Cry
There goes your warranty
You seriously need to get rid , and buy a lotus or Morgan Rolling with laughter
Post #317171 19th Mar 2014 12:52pm
Caterham
erm....the blank is still there hence the mil light.
if I get shot of this it'll be back to a Caterham.
within reason the only couple of vehicles that interest me at the moment are the def and Caterham.
Post #317172 19th Mar 2014 1:01pm
Cakey
One consolation the dealer may not know a lot about defenders .
Love ur threads by the way, cheer up my day Thumbs Up
If u get a caterham let me know when u join that forum. Now that will be entertaining . If they are like the tvr or lotus I had
Popcorn popcorn beer Thumbs Up
Post #317177 19th Mar 2014 1:19pm
Page 4 of 5 <12345>
