Home > Td5 > Unreliable Fuel Reading
Derrickthedefender
United Kingdom 2004 Defender 90 Td5 SW Zambezi Silver
Okay so I came to start my truck up, knowing that it was just about to hit the orange on the fuel guage, so the fuel light wasnt even on yet.... yet it wouldnt start Mad
anyone any ideas why it would say it has fuel, yet not start due to there being no fuel!? A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Yes the name for my 90 is Derrick!
Post #317026 18th Mar 2014 10:39pm
Derrickthedefender
by the way, it was on a flat surface, not a slope
Ben A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Post #317027 18th Mar 2014 10:40pm
The obvious one is that the sender is either faulty or poorly adjusted. Darren
Post #317032 18th Mar 2014 10:47pm
StephenO
I've faffed about with my sender after fitting a new tank (90 300tdi) but still gives false reading above half a tank. How do you adjust it? 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #317042 18th Mar 2014 11:46pm
It could be soemthing as simple as bending the float arm slightly so that it registers the full range of travel. It's also worth checking that it's not installed in such a way that it's catching on the side of the tank or the fuel pick-up. Darren
Post #317072 19th Mar 2014 7:47am
JWL
As it's a Td5, is the fuel pump running? There may be fuel in the tank but not getting to the engine, there's many other reasons why it's not starting.
Post #317077 19th Mar 2014 8:55am
Derrickthedefender
Ah right okay, I'm not entirely heeled up on this area...
So how do you properly check the fuel pump? Or adjust the sender? A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Post #317162 19th Mar 2014 1:33pm
