![]() | Home > Td5 > Unreliable Fuel Reading |
Derrickthedefender Member Since: 28 Jan 2014 Location: South Posts: 294 ![]() ![]() ![]() |
by the way, it was on a flat surface, not a slope
Ben A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!! Yes the name for my 90 is Derrick! |
The obvious one is that the sender is either faulty or poorly adjusted. Darren
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 ![]() ![]() |
I've faffed about with my sender after fitting a new tank (90 300tdi) but still gives false reading above half a tank. How do you adjust it? 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
It could be soemthing as simple as bending the float arm slightly so that it registers the full range of travel. It's also worth checking that it's not installed in such a way that it's catching on the side of the tank or the fuel pick-up. Darren
As it's a Td5, is the fuel pump running? There may be fuel in the tank but not getting to the engine, there's many other reasons why it's not starting.
Ah right okay, I'm not entirely heeled up on this area...
So how do you properly check the fuel pump? Or adjust the sender? A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!! Yes the name for my 90 is Derrick! |
