Home > For Sale & Wanted > [Wanted] Under dash speakers
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I'm after either a pair os single one of these, one of mine has broken, they are PRC6348, just wondered if anyone has upgraded and got some of these in a dark recess of the garage?!!
They are slightly 'thinner' than a normal speaker because the wiper motor is behind the passenger one....
[/URL][/img]
[/URL][/img]
Post #316675 17th Mar 2014 6:42pm
bear100
I replaced mine with a set of vibe slick 4, only cost £25 at halfrauds! Really good quality and great sound
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #316683 17th Mar 2014 7:16pm
Lambley
Did they fit ok or were spacers needed?
Post #316712 17th Mar 2014 8:00pm
Tiger
I have a pair of 2004 original under dash ones in the garage somewhere
Post #316733 17th Mar 2014 8:16pm
bear100
Fitted well, no spacers needed, and used existing screw holes Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #316744 17th Mar 2014 8:25pm
Lambley
Thanks for the replies, I reckon the Vibe ones you fitted might not fit direct to mine, I looked them up and they have a mounting depth of 41mm (which I think means the depth of speaker behind the mounting surface), I've just measured my old ones and they are about 23.
Tiger, let me know if you find them, but again, they have to be very slim so they don't hit the wiper motor, or come with spacers?
Post #316805 17th Mar 2014 9:52pm
shaggydog
I have a pair here can send you for postage cost?
Give me 2 min for pic upload!
Post #316808 17th Mar 2014 10:02pm
shaggydog
Were removed from my 200tdi Dash which has the same enormous wiper motor you have.
They worked when removed but have been sat in my "bits and bobs" box for at least a year so may have suffered from lack of use.
Happy to send them to you tomorrow for Postage cost if your interested?
That said, I would also recommend upgrading your speakers as modern speakers can make even a old cheepo radio sound better.
I used a spacer ring from halfruads to space out enough to put in a 10cm speaker and the difference was instantly noticeable!
Post #316814 17th Mar 2014 10:09pm
Tiger
I've also got some MUD spacers kicking around
Post #316820 17th Mar 2014 10:14pm
Lambley
Brill Shaggydog, I'll have them if that's ok, for what I need them for (trips for me and the dog to the fishing lake) they will be more than sufficient, i'll send you a pm now.
Post #316825 17th Mar 2014 10:21pm
shaggydog
Replied! Thumbs Up
Dog
Post #316836 17th Mar 2014 10:52pm
