Home > For Sale & Wanted > [Wanted] Under dash speakers |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1923 |
I replaced mine with a set of vibe slick 4, only cost £25 at halfrauds! Really good quality and great sound
2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
17th Mar 2014 7:16pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Did they fit ok or were spacers needed?
17th Mar 2014 8:00pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
I have a pair of 2004 original under dash ones in the garage somewhere
17th Mar 2014 8:16pm |
Fitted well, no spacers needed, and used existing screw holes 2016 Range Rover Autobiography 4.4 TDV8
17th Mar 2014 8:25pm |
Thanks for the replies, I reckon the Vibe ones you fitted might not fit direct to mine, I looked them up and they have a mounting depth of 41mm (which I think means the depth of speaker behind the mounting surface), I've just measured my old ones and they are about 23.
Tiger, let me know if you find them, but again, they have to be very slim so they don't hit the wiper motor, or come with spacers? Cheers |
17th Mar 2014 9:52pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I have a pair here can send you for postage cost?
Give me 2 min for pic upload! |
17th Mar 2014 10:02pm |
Were removed from my 200tdi Dash which has the same enormous wiper motor you have.
They worked when removed but have been sat in my "bits and bobs" box for at least a year so may have suffered from lack of use. Happy to send them to you tomorrow for Postage cost if your interested? Click image to enlarge Click image to enlarge That said, I would also recommend upgrading your speakers as modern speakers can make even a old cheepo radio sound better. I used a spacer ring from halfruads to space out enough to put in a 10cm speaker and the difference was instantly noticeable! |
17th Mar 2014 10:09pm |
I've also got some MUD spacers kicking around
17th Mar 2014 10:14pm |
Brill Shaggydog, I'll have them if that's ok, for what I need them for (trips for me and the dog to the fishing lake) they will be more than sufficient, i'll send you a pm now.
17th Mar 2014 10:21pm |
Replied!
17th Mar 2014 10:52pm |
