Home > Puma (Tdci) > Light switches: where can I buy these online? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2640 |
Hi all
I need a couple of these switches, anyone know where I can find them online? thanks! |
6th May 2010 9:40am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Try TLO in the disco3 site, they look like disco2 spotlight switches Original Member Pie n Pea Club.
110 HCPU Tipper |
6th May 2010 10:08am |
LR Part YUG000540LNF (cost is + or - 7.20£, 8,50€) same form factor for Puma Defender (I installed it on mine) or here on-line BRIT-CAR.CO.UK Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th May 2010 11:29am |
Thanks man, did you also need a separate connector? Someone else said I need this connector: http://shop.dingocroft.co.uk/acatalog/Elec...#aZZPLUG01 |
6th May 2010 11:51am |
yes correct!!! I bought it from Dingocroft also!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th May 2010 11:54am |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
I Bought those in http://www.rimmerbros.co.uk/ at 7.06 GBP (VAT Incl) + Shipping cost
http://www.rimmerbros.co.uk/Item--i-YUG000540LNF Delivery time due the volcano was a little bit too long but no their fault No complains at all Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
6th May 2010 12:33pm |
n00b question, but what does the connector do? And why can't you use the switch on its own? |
6th May 2010 12:38pm |
I suppose that you'll build the wiring loom for the front foglight..... The defender haven't fog light wiring predisposition so how you can connect electrically the switch to the wires? by the right connector.... the fogswitch pinout is (YUG000540LNF): 1 = earth switched 2 = +vehicle illumination ("on" with sidelights) 3 = earth (ground) 4 = 5 = + control light (small orange led, feed from powered device) see HERE for general infos and DOWNLOAD ME for LR Driving Lamp Installation instructions Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th May 2010 1:58pm |
